Question about LaCie (300728U) 250 GB Hard Drive
Lacie usb 250gb Not recognized or found by PC
This device has work flawlessly in past for monthly backups. I installed new Epson printer today and now USB ports don't find or recognize the Lacie drive... Andy ideas?
    Problem Solver:
  • 9 Answers
Right click on My Computer > Manage > Device Manager. Do you see any yellow exclamation points? If so, you have conflicting devices. I'd need some feedback at this point to continue to help you, but if you double-click on the yellow mark, a window will popup. See if you can troubleshoot or rollback some drivers.
Posted on Jul 27, 2007
SOURCE:
My LaCie 250 GB external hard drive is plugged in and the orange light is on. It's not showing up in my computer but when I go to device manager it's there. If I double click on the device it says code 10...
Unfortunately hard drives are a pain when they have problems.
First try a different USB port to make sure that there is a problem with the port.
With my experience on broking external hard drives, I am guessing that your HDD motor is not spinning.
Some things you can try for this (should be done with an experienced individual)
- Take the HDD out of the case and place it in another external case (easily found at Best Buy or online (I buy mine from Milwaukee PC)). This solution has helped me in the past.
- If the drive is failing to initialize you just may have to replace it. If you want your files to be recovered you can send the drive in to repair shops and they can try to recover the files BUT this is NOT cheap.
- Simply buy a new external, they are pretty cheap these days (especially 250gb).
Hope this helps :)
Jan 25, 2011 | LaCie (301074) 80 GB Hard Drive
Lacie RUGGED 250GB not recognized by my PC
I think the migration assistant (in the utilities file in your application folder) can transfer files direct via USB.
Jan 23, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Vista (32) will not recognize my lacie d2 external harddisk
solved: after referring to the userguide, I found that I formated my drive with a OS format, which can not be recognized by VISTA >> formated to FAT32 and now it works...
Jan 03, 2009 | LaCie d2 Extreme 250GB External with...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie Hard drive not recognized
If your computer recognized the hard drive before you have installed your last operating sistem(s) that can be the problem. Your operating sistem or BIOS is not seeing your hard drive any more. Installing a new operating sistem is going to solve your problem but try another one, not the operating sistem you used until now.
Dec 26, 2008 | Computers & Internet
Lacie external HD problems
I would suspect your USB drivers. Go into device manager and remove (uninstall) any device under the USB heading. Reboot and see if it works better. Also I would try the drive on another computer to make sure it is working find and try a different USB cable just in case.
Jan 17, 2008 | LaCie (300770) 250 GB Hard Drive
HD recognized, but not accessible.
-Right-click on My Computer and select Manage. -On the left, in the Storage folder, click on Disk Management. -If the Write Signature Wizard opens, follow the wizard. -If the wizard did not open, you can right-click on the disk "Unknown" in the bottom part of the Computer Management window and select Write Signature and OK. (If the disk is not labeled as "unknown" then it has already been initialized and you can proceed with formatting). -Then proceed with formatting below. Formatting: -Now right-click on the unallocated space of the disk and select New Partition. -The New Partition Wizard will open. -Click through the wizard. You can leave most settings at their defaults, but make sure to select the option to perform a Quick Format. This will perform a quick format, that will only take a few moments (depending on the size of the drive). Once completed, your disk should be accessible with the chosen drive letter in My Computer and Explorer.
Jun 22, 2007 | LaCie (300728U) 250 GB Hard Drive
Hard drive not mounting
If you still have the files on your pc and just use the drive as a backup, then there is nothing lost yet, and no need to recover, just return to retailer. But if there is any sign of life, check; Right Click My Computer>Properties>Device Manager>Hardware,see if your Drive is in the list, if not, on top right there is an icon for scan for new hardware. See if your PC can find your drive, if not return it.
Nov 03, 2006 | LaCie d2 Extreme 250GB External with...
LaCie (300728U) 250 GB Hard Drive Logo
259 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
