Question about JVC AV-27530 27" TV
Half a screen
Hi, I own a JVC AV-21SX2EK TV and only recently the screen has dropped to about half way. It sort of flickers there and may move back towards the top with a tap on the side but invariably moves back to about half way again. Any ideas? Dan
  • Daniel Daniel Jul 07, 2007
    Fab! I can solder but can you tell me where the ID is?
  • 398 Answers
The solder joints have cracked on the vertical output IC. If you have soldering experience you can resolder them yourself but if not then let a qualified tech handle it for you.
Posted on Jul 07, 2007
  • Mike Longo
    Mike Longo Jul 09, 2007
    Look at the jack with 4 wires going up to the yoke, the large set of coils on the neck of the picture tube. 2 wires are for horizontal and 2 are for vertical. Look at the bottom of the board and follow where those 4 wires go. The 2 horizontal wires will go towards the flyback transformer and the large horizontal output transistor. The other 2 wires will go toward the vertical output IC. Resolder the pins of that IC and while you are at it, resolder the pins of any other IC or transistor that is mounted on a metal heat sink, as well as any other solder joints that look discolored, cracked or weak.
SOURCE:
One half of my screen is dark the other half is light
your bulb is going out if you tape the back of the tv the screen should flicker
Aug 19, 2011 | JVC Televison & Video
JVC AV48WP30 Projection TV..Half picture distorted and flickering
Ur convergence is dead.Must replaced the 2 convergence ICS and all it resistors.The shop will cost U $300 for parts and parts.
Feb 10, 2010 | JVC AV-48WP30 48" Rear Projection...
My tv the JVC AV-65WP74 the tv works its just the colors are split in half one is blue and other red like if it was 3d tv
hi, needs convergence ic`s replaced, possibly a couple of precision resistors, it needs a tech, this is not an easy job for a non tech, here in central fl. it runs $256, hope this helps, video-tek
Jun 04, 2009 | JVC AV-65WP74 Rear Projection Television
Color convergence drops on left side
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Mar 13, 2009 | JVC AV-48WP30 48" Rear Projection...
Television fault
it is not worth fixing get a new tv
Oct 31, 2007 | JVC AV-27020 TV
Black menu screen pops and hides half the tv.
that is close caption, get your remote control and press the close caption button.that's it
Black Menu Appears
set is in the text mode.
Aug 17, 2007 | JVC AV-27S33 27" TV
JVC AV-48WP74 48 in.
The convergence circuit needs repaired. I did the same job yesterday on this model. I not only replaced the convergence ICs, but, I had to replace a couple of resistors and a coil. The convergence alignment was minor after that.
Jan 22, 2007 | JVC AV-48WP30 48" Rear Projection...
JVC AV-27530 27" TV Logo
66 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
