Question about Kohler K 304 Rite Temp Pressure Balancing Valve
Slow stream In Shower After Replacing Kohler Mixing Valve
I replaced my Kohler 304K Rite Temp assembly for my Kohler Forte Shower set. After turning the water main back on, the valve mixes as it should, but when I turn the valve stem to the full "OFF" position, there is a light, but steady stream of hot water continuing to pour through the spout. Any ideas?
3 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Kohler k-304 rite temp valve. The shower started
Try to use the user and maintenance manual --->link
Posted on Nov 09, 2010
heatman101
  • 43501 Answers
SOURCE: I have a Kohler
The problem is that the pressure balance unit is stuck...therefore no hot water...it is not sensing the cold water pressure....so it will not allow hot water to flow...
The lack of use is actually a bad thing as the rubber and such can adhere to the metal and stick the unit...
You maybe able to free it up, but it probably will never work correctly...
I would just replace the pressure balance unit to be sure that it is working correctly and safely...
heatman101
Posted on Jun 23, 2011
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
Very little cold water from shower valve
If this is a new installation and has always beenj this way, then I would suspect that there may be an obstruction in the cold water line leading to the valve. Or something stuck in the valve at the point where the cold water is connected. If someone has worked on thius valve recently , then I would suspect that they got the valve cartridge in backwards, If the catridge is not placed in the valve correctly the opperation is messed up.
May 06, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Only warm water from the tub/shower
You can cap the lines at the tub faucet to rule out tub faucet. It maybe mixing there.
Faucet may be bad also the safety stop will alow you to change water temp it can be tricky to adjust water temp.
May 02, 2010 | Moen 1 Handle Lever Shower Faucet With...
Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Dec 25, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Kohler shower facuet pressure balancing problem?
ever since the pressure balancing regulations came out for shower valves, they have went from simple to very complicated devices. sounds as if some foreign material caused the valve to stop working. that valve is quit difficult to reassemble correctly because there is only one way it works and can be assemmbled many ways that do not work concerning alignment of the ports. if you dissassemble it and check that all the moving parts are functioning in the balancing cartridge you can then look closely at the alignment of the ports on the cartridge that the handle is connected to. understanding how the port align as the handle is turned should assist you in assembling it correctly......hope this helps.
Jan 20, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Pressure problem with Kohler shower faucet??
Hi pglaw,
My best guess is the supply valve for the hot side isn't open all the way. This valve is right on the valve and is accessed by taking off the front cover plate. This would still allow the pressure balancing valve to let water through but then you would have a small flow on the hot side.
If this isn't it then then cartridge is bad.
Please rate this response and good Luck,, phil
Dec 30, 2008 | Kohler K-T10335-4-CP Lyntier Rite-temp...
No water coming out of my Kohler Forte R10275-4-BN shower valve
This is a pressure balancing valve that needs both cold and hot water pressure to operated. It is an anti-scald safety operation.
Good Luck, Phil
Dec 25, 2008 | Plumbing
Kohler K 304 Rite Temp Pressure Balancing Valve Logo
Top Kohler Welding Tools Experts
Bill Boyd
Are you a Kohler Welding Tool Expert? Answer questions, earn points and help others
