Question about Baxter Ovens
Baxter ov300e oven digital board read (0f) all the time and the oven keep heating until the oven shot off
5 Suggested Answers
  • 910 Answers
SOURCE: Hi! I have a baxter OV300 1999- The rack stops
I suspect the drive bel tis worn and slipping.
Please refer to Page 28 of the manual at the link below to inspect the belt.
https://feg.hobartcorp.com/resourcecenter/ProductDocumentation/F36704.pdf
If this is OK and/or you need any further assistance then please just ask.
Posted on Jul 21, 2011
SOURCE: need to set clock for daylight time on baxter oven
With the oven on hold the time up or down arrows until the time begins to change.
Posted on Dec 30, 2011
SOURCE: baxter ov300e electric oven
When you say the oven doesn't want to turn on are you referring to the control board wont turn on? Or are you saying that the oven wont heat when it gets too hot?
SOURCE: I have a problem with a Baxter OV300E Oven.
Check to make sure the draft motor, directly above the control panel in the front right corner, is running. If it is running then you could have a dirty air switch, if you open your control panel you will see a metallic disk with a black rubber hose and two wires going to it, this is your air switch. Try disconnecting the hose and blowing out the air switch and hose with compressed air. If this doesn't work you may need a new air switch. If the motor isn't running at all you could have a bad motor or a bad ignition module which powers the fan.
Posted on Jan 13, 2012
I need wiring digram for baxter oven ov300e
Request the wiring diagram directly from Baxter.
Feb 23, 2017 | Baxter Ovens
I will need to get a Baxter OV300EDD oven through a 35" wide door frame. Considering the oven is 37.49" deep, could I remove the doors off the front of the unit so that it will fit through the...
You can remove the oven doors, hinges, control panel door, and top oven trim, if needed. That will definitely reduce the width enough to squeeze it in.
Aug 17, 2011 | Baxter OV300E Stainless Steel Electric...
I have a problem with a Baxter OV300g Oven. The Automatic Ignition System keeps Flashing 1-flash Air flow problem, can you help me with this. Thank you.
Check to see if your draft inducer (exhaust fan) is running, if it is then you could have a dirty/bad air switch, the component with the small black hose running to it and the two wires on the face. To check an air switch using a multi-meter set it to 40 VAC and place a lead on each terminal, if you are getting a voltage reading over 1 volt, replace the air switch, if you have zero volts, the air switch is closed and working. Aside from a bad exhaust motor or air switch there could be many things causing that error.
Jul 30, 2011 | Baxter OV300E Stainless Steel Electric...
Need to set clock for daylight time on baxter oven ov300e
Nov 07, 2010 | Baxter OV300E Stainless Steel Electric...
When #9 program for Bagels is running , the temp drops 130 degrees before cycle is complete. also having to reset breaker several times
It's normal for the oven to drop temperature during the first 4 minutes of a bagel cycle, although the temperature should recover to 525 before the end of the bake. If your breaker keeps tripping you could have a blown heating element and should call your local authorized service provider, I wouldn't recommend attempting to repair this one on your own.
Sep 28, 2010 | Baxter OV300E Stainless Steel Electric...
How do you change clock time? Hours,minutes,etc
With the oven on hold the up or down arrows to the right of the clock display until you've reached the correct time.
Oct 11, 2009 | Baxter OV300E Stainless Steel Electric...
When we turn the switch on, the light inside the oven goes on, but the touch pad does not come on, it comes on by itself after a while, or will shut off in the middle of cooking.
Control board defective. Before replacing the control board make sure that your incoming water pressure is no higher than 20 psi and that your door gaskets and fan seal is intact. Torn gaskets or a worn fan seal will allow steam to enter the burner compartment and damage your control board.
Sep 12, 2009 | Baxter OV300E Stainless Steel Electric...
I have a problem with a Baxter OV300E Oven. The Automatic Ignition System keeps Flashing 1-flash Air flow problem, can you help me with this. Thank you.
Feb 20, 2009 | Baxter OV300E Stainless Steel Electric...
Baxter ov300e electric oven
Oct 19, 2008 | Baxter OV300E Stainless Steel Electric...
Ovens Logo
Top Baxter Ovens Experts
Lawrence Oravetz
shannon816
Are you a Baxter Oven Expert? Answer questions, earn points and help others
