Question about American Standard Plumbing
Sottini 9052.500 Temp adjustment
Lav faucet needs to have more hot water. How adjust cartridge for Alchemy Sottini single handle faucet?
arealplumber
  • 33 Answers
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Posted on Dec 05, 2008
  • 68 Answers
SOURCE: Single handle Pioneer shower faucet
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
dragonsthatk
  • 547 Answers
SOURCE: kohler single lever kitchen faucet,no hot water
no its somthing in water filter rust or dirt in line.take apart and drain line. thank you for useing fixya please rate me
Posted on Feb 26, 2009
  • 659 Answers
SOURCE: Adjusting single leaver faucet handle
The little wrench tightens the tension ring that fits on the inside of the retaining nut right under the handle. You fit the little "arms" in the notches.
Posted on Apr 06, 2009
snap101
  • 117 Answers
SOURCE: I just installed a new cartridge in a moen single
try and pull the cartridge out and look in there with a flash light and make sure there isn't any think lodged in the hot water side of the faucet, you might even want to leave the cartridge out and turn the water back on to try and flush it out. alot of times rubber from the old cartridge gets stuck in there as you are pulling the old one out especially if it's stuck in there good
Posted on Jul 29, 2009
Adjust handle stop on Metro high arc
Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
May 08, 2013 | Hansgrohe Metro E Single Handle Deck Mount...
Single handle shower faucet never gets hot. temp is turned all the way up on the gears.
If you are sure anti-scald adjustment is all the way up,then you have a bad cartridge,you need to replace the cartridge to solve the problem.
May 29, 2011 | Price Pfister Single Lever Handle Faucet...
We recently installed a Moen single handle faucet in a refinished shower after having a plumber replumb the front of our house. Handle appears to be properly installed. Now there is no hot water or even...
u need to adjust the scald protector all single handle units are shipped in cold position for safety reasons if have paper work for handle it explains how to adjust if not unscrew handle and remove on handle / valve stem will see a red and a blue plastic clips pull back clips and turn slightly and push back do this till desired hot and cold setting are to your liking replace handle and your done
Dec 17, 2010 | Moen & One Handle Tub & Shower Faucet
Can I adjust the hot water temp if I have a Posi-temp faucet?
should have a gearlike part under handle that can be adjusted so as to allow the handle to rotate to more hotter (left) or warmer
Dec 08, 2010 | Moen Posi-Temp Single HandleTub And Shower...
We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
Go to link below for a part's diagram if needed.
TO ORDER PARTS CALL: 1-800-465-6130
www.moen.com
Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
Single-handle Glacier Bay shower faucet, hot/cold reversed
Behind the handle check to see if it has a dail to take out and replace at a different postion this will change the hot and cold. It a anti scald protection device. Don't remove cartridge just adjust dail.
Mark where you start and take out and move a 1/8-1/4 turn at a time and replace til temp desired. It has teeth like a gear you move to adjust temp.
May 11, 2010 | Delta & Single Handle Shower Faucet
I have a single handle shower valve by Moen. Water is slowly leaking past the valve when shut off. I got the handle off but need to know how to further disassemble so I can replace whatever seal or o-ring...
there is a clip holding the cartridge in place. You need to remove that and then there is a little plastic throw away tool that comes with a new cartridge that you use to break the seals loose on the old cartridge....then you use a pair of channel locks to grab the stem and pull it out. The new cartridge should come with detailed instructions.
If it is a moentrol valve...the part number is 1225 and if it is a posi-temp it is a 1222. Moentrol you pull out to turn on and then left and right for temp adjustment. Posi-temp just turns to turn on and you turn from cold to hot to adjust through the temp range.
Dec 03, 2009 | Moen 3175 Legend One Handle Shower Faucet...
My delta 132900 gets too hot.
With these Faucets, you can remove the handle and make adjustments to the max Hot water setting (scald guard).
You may also have a faulty or lime-covered cartridge.
SEE THIS SITE for making adjustments/replacing the cartridge.
Thanks for using FixYa - a 4 THUMB rating is appreciated for answering your FREE question.
Aug 23, 2009 | Delta & Single Handle Shower Faucet
Single handle shower no hot water.
when shipped the anti scold is in cold mode remove center handle will c a blue and red adjustment pull red off and move up or down and replace check for desired temp if cold or to hot readjust
Jul 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Plumbing Logo
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
