Question about Husqvarna Garden
What is th biggest bar that a husqvarna 135 x torq can use
I bought a new husqvarna 135 x torq with a 14 inch bar and i was wondering can the saw drive a bigger bar
  • 26 Answers
Husky suggests a 14" or 16" bars. Here is the manual!
Cheers!
http://www.manualslib.com/manual/584805/Husqvarna-135.html?page=32#manual
Posted on Jul 07, 2014
  • 211 Answers
SOURCE: husqvarna chain saw, model 455 will not oil properly bar and chai
hi cindilou50
check the oil filter from the oil tank,the oil line ,the worm gear and the oiler under the clutch.Clean the ways where the oil goes with compresed air.(after you fill out the oil tank)Also check the oil hose.
best regards savumihai71
Posted on Dec 01, 2008
  • 11 Answers
SOURCE: Husky 460 chains too long (or is the bar too short)
I'm am guessing the bar is not a stock bar or was miss matched at purchase by the dealer.
Have dealer look up factory bar to see what was original and either go with that or if you already have it. ask for a new rim sprocket with 1 extra tooth. If you don't have a replacable sprocket then best bet would be to have chains custom build which usually is the same price, if they treat you right.
Remember the new sprocket MUST be the same pitch and width of your chain and bar and they do make a large and small ID also.
Last resort If not wanting to trash a new bar or change out sprocket, run a couple chains when they get loose have your dealer take out a link.
Also a stihl 20" can be a 72 drive link chain where a husky could be a 70 or other.
Everything must be matched, hard nose bar is exception.
Bill Czerkie
Posted on Feb 03, 2009
SOURCE: Where is the bar oil adjusted from on husqvarna 345
Turn the Hus 345 chain saw upside down, you may see a little Icon of a oil droplet and a + - arrow by the chain. THe adjustment screw is not pictured in any of the standard user manuals,. but it is a small black slot headed screw over a rectangale metal tab by the chain. I believe if you turn it counter-clockwise, it will give you more oil,, It did for me. If you have the bar off, you can start the saw and see it come out the hole, that would verify your oil pump is working. Make sure the holes on the bar are clean also. running the saw at a fast idle for 1 min should oil the chain well enouth that it starts spraying off the end of the bar when you gun the engine.
Posted on Apr 27, 2009
  • 376 Answers
SOURCE: We have a model 435 husqvarna 16
Yes, no problem
Posted on Jun 13, 2009
dontbother10
  • 2220 Answers
SOURCE: How interchangeable are replacement chain bars for
Your question can't be answered as aked.
If your saw requires an Intenz 14" Bar it's Oregon pns 140SDET041 or 140GPET041. Part number 140SDEA041 if not Intenz.
Plug in your requirements here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Once you get a part number it can easily be converted to other manufacturers numbers. HTH
Lou
Posted on Nov 03, 2009
Chain and bar gets hot and cant saw straight
this sounds someting like the bar is worn out and now you have to tighten the chain so tight (to keep it on) that it's heating up and makiing things worse, or is auto chain lube not pumping oil up to chain ??? either way if you run long without chain lube your back to reason 1
Feb 26, 2015 | Husqvarna 450 Rancher 18-Inch 50.2cc...
Why saw binds in middle of cut ?
check on which way you are cutting if what you are cutting has a load on it it could be pinching your bar
Oct 08, 2014 | Husqvarna 460 Rancher 20-inch 60.3cc...
How to remove the chain from a husqvarna 235e chainsaw?
Like this or pretty close.
  1. Cock brake while expanding chain brake binder by pulling brake handle towards left-hand (wrap-around) handle grip, hard, until it locks in place.
  2. Loosen 2 brake-asssembly-and- bar retaining nuts but do not remove yet.
  3. Unscrew (turn CCW) bar adjustment screw on front face of unit in order to shorten bar and slacken saw chain.
  4. Slip chain off bar over bar tip and towards inward side of bar.
  5. Remove two nuts loosened in step 2 and pull brake assembly and bar straight out and off bar mounting studs.
  6. While rotating clutch/brake-drum, maneuver saw chain off sprocket and around drum perimeter to remove from saw.
  7. Repeat/reverse steps 6 thru 1 in that order to reassemble.
25045742-0m3nstwfcb55vn4usb1qox2f-3-0.jpg 25045742-0m3nstwfcb55vn4usb1qox2f-3-2.jpg
Sep 01, 2014 | Husqvarna 14-Inch 34cc Gas Powered...
What's the biggest bar i can put on a husqvarna 240?
The 240 origanaly had a .325 pitch chain and ran a 15" bar, it is not avisable to go any longer as the power loss will be great, the later machine had a 3/8 chain and ran a 14" bar, the loading on this smaller chain chain would allow you to fit the 16" bar, i think this will be the longest bar you can fit due to power and chain oil pump capacity
Jul 13, 2012 | Garden
I need to buy torx screwdriver to adjust the carb on a 235-e husqvarna what size do i need
Its not a torq head, there is a part no. for it 530035560 check the web i am sure there are people selling it.
Jun 10, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
What is the biggest bar and chain i can use
The recommended length of bar for the 460 is 13 to 20 inches. I wouldn't go over the recommended length as it would put extra strain on the motor.
Dec 05, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
How interchangeable are replacement chain bars for older Husqvarna chainsaws? I've never replaced one before and was considering buying one from Sherril on-line which is on sale, a 14 inch Husqvarna Intenz...
Lou
Nov 03, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Bar size
According to Husqvarna a 3hp saw will allow bar sizes 13"-20"
Sep 06, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
138 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
