Error code F 50
Checked speed sensor on drive motor ok
    Sergeant:
  • 291 Answers
Unfortunately there are different codes for different machines. I will need the model number to help you. Unless you know what F 50 means. Still model number would help. Thanks
Posted on Jan 13, 2013
Error 22-23-26
Precor Error Code 23
Error Code: 23 Manufacturer: Precor
Model: All Models
Error Description: Error 23, Motor Pulses Missing after Start Up - Indication that the speed sensor signal was lost while the unit was in operation. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Intermittent connection of speed sensor or drive motor wiring.
  5. Badly worn drive motor brushes not able to make proper contact with drive motor commutator.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Test all wiring and wire connections of the speed sensor and drive motor. Replace or repair necessary wire connections or wiring.
  5. Inspect and replace drive motor brushes if necessary.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Precor Error Code 22
Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
Recommended Action:
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  4. Damaged speed sensor target.
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Precor Error Code 22 Precor Error Code 23 Precor Error Code 26
May 13, 2014 | Precor C964 Treadmill
Precor 9.41 si error code 22
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Recommended Action:
Apr 20, 2014 | Precor 9.41 si Walking Belt
Code 22 flashed up and motor wont turn
Model: All Models
Recommended Action:
Nov 29, 2013 | Precor 956 Remanufactured Treadmill
Precor M9.35 error 22
Model: All Models
Recommended Action:
Nov 12, 2013 | Precor 9.35 Treadmill
Error code 22 ,treadmill 9.25 precore stops
Model: All Models
Recommended Action:
Sep 07, 2013 | Precor Exercise & Fitness
Hola Ernesto, congratulation for your seccess,, thanks for the great support you had provideded to the community. I own a precor C934 have lower Controller, LPCA problem, and I would like to check if
Thank you brother.
That causes can be
1) optical infrared speed sensor is obstructed.
2) drive motor brusher are bad.
3) speed sensor position is incorrect
4) speed sensor potentiometer adjustment is incorrect
5) speed sensor is faulty.
6) lower PCA is bad
7) lower PCA to upper PCA interconnect cable is bad
8) upper PCA is bad
Remedies: vacuum the drive motor pay attention to speed sensor .
b) motor brusher do not make suffciente contact repair
c) adjust the speed sensor see the scheme attached.
d) locate the speed sensor potentiomente on the lower PCA.set the potentiometer in mid-range
e)measure voltage D.C. for 5vdc, two fo the leads will toggle between 0vdc-5 Vdc.as you rote the speed sensor.
f) substitute a known good lower PCS for determine g) substitute a known good interconnect cable h) substitute a known good upper PCA for determine if is faulty.
God bless you
see the block diagram and my personal TIPS for motor in treadmills
Oct 11, 2012 | Precor Exercise & Fitness
Precor c966 error 22
Model: All Models
Recommended Action:
Sep 27, 2012 | Exercise & Fitness
Precor 9.35 Problem--Please Help!
Model: All Models
Recommended Action:
Jul 21, 2012 | Precor 9.35 Treadmill
Speed goes fast than slow than fast- error code 22
Model: All Models
Recommended Action:
Oct 30, 2010 | Precor 9.31 Treadmill
My Precor 9.31 made a loud "click" sound and turned off while I was walking on it. Error 22. What does this mean?
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started.
1. Drive motor brushes are bad or the lower PCA is bad.
Apr 15, 2010 | Precor 9.31 Treadmill
Washing Machines Logo
Top Washing Machines Experts
