I have a smartdisk firelite fwf120-n and no usb cable, where can i buy one?
  • 27,725 Answers
Try local computer outlet or Ebay
You might get these on Ebay im not sure which country you are in this might guide you to one You could get this on Ebay if you dont have an account you will need to create one. https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also Add your Postal Adress also Add a PayPal account. Click on the Ebay tab on top of page from the drop down list you will see specific pages. On left hand side on Ebay summary page you will see the PayPal link. when you get to the PayPal login page at the bottom you will see new to paypal sign up tab. Paypal to create an account PayPal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a Postal Adress. Be very specific when you type in the search. Always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. Hope this helps.
Posted on Jan 14, 2013
SOURCE: Smartdisk Firelite 80GB-Stopped Working
I had the same problem with my firelite usbflb80-c, and carefully took the case off, 4 screws (one screw under the void if broken warranty sticker) my drive had somehow wiggled it's way out if the connection pins. Figures, with 5 yrs of use, all the traveling and occasional dropping. So I carefully pushed the drive back in place until I couldn't see connection pins any more. I plugged it into my computer before I closed it back up. THANKFULLY an easy fix, but I double checked for breaks or cracks before I closed it up. :o) YAY, I thought I had lost all my files!
Posted on Apr 23, 2009
Crankstart
  • 696 Answers
SOURCE: my smartdisk firelite does not appear anywhere on my computer
Sounds like you have a hardware failure either in the drive enclosure or the hard drive itself.
I suspect you may get lucky and find out it's just some of the circuitry in the smartdisk shell that is damaged.
Take the Smartdisk unit to your nearest PC shop and ask the technicians there to remove the Hard Drive and put it in a new enclosure to test it. If it works in the new enclosure, buy the enclosure and your done. If it doesn't work in the new enclosure then you may be suffering from worse issues that will require the help of a pro.
Either way let me know how you make out, if you need a pro for the next step, reply back with you location(Country, State, City) and I will refer you to the closest facility who can assist you.
Hope this Helps FixYa,
Chris
Posted on Aug 19, 2009
SOURCE: Have a FireLite Smartdisk for the old iBook G4.
I called Apple - purchased a 400 - 800 adaptor.
Posted on Sep 07, 2009
  • 832 Answers
SOURCE: External smartdisk firelite
It seems that you will lose your files. These file already
infected with virus, and corrupted it. There's no other
way but to reformat your smartdisk.
Posted on Oct 08, 2009
  • 2678 Answers
SOURCE: When I plug my smartdisk firelite USBFLB40C into
If it is new and has not come pre formatted then you need to format it to match the system as it still could be in RAW state, but I would expect usb devices to be preformatted. (not always the case though)
A bit of history:-
FAT32 recognised by all windows systems ( but does not support files more than 4GB)
NTFS recognised by systems other than FAT32 (and supports files above 4GB)
FAT 32 was the native format for WIN98 but unfortunately when XP came along many companies continued to format in FAT32 for XP machines especially for the home user. (and XP would run quite happily with the format)
NTFS was and is the more stable of the two.
Posted on Jul 26, 2010
Trying to connect my old Smartdisk USBFLB120 to my Toshiba Laptop with Windows 7 64 bit - can't get drive to recognize as drive - Lapop sees device but says it is unavailable
Change you usb port or replace the smartdisk's usb cable, probably the current one if broken. Also restart the pc whilst the smartdisk is connected. It shd be recognised now.
Jun 06, 2011 | SmartDisk FireLite USBFLB120 120 GB USB...
On my smartdisk firelite the conection that excepts the usb cable has broken. I need data thats on the hard drive how would I get this info off the firelite?
you can open the case and remove the hard drive and install it in a new external usb case for it.
you can find out what type of case you need after you open it. it could be either a SATA connection or IDE.
If it is a SATA and you got a SATA cable/power you could also just install it directly into your computer and grab the files you need.
Mar 11, 2011 | SmartDisk FireLite - 80GB - 5400rpm - USB...
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Mar 24, 2010 | SmartDisk FireLite® XPress 120 GB USB 2.0...
My firelite smartdisk model cord does not fit into my new macbook air. can i buy a cord that has a usb port at one end? thx
The MacBook Air has one USB port. Most computer stores have many different plugs on the other end that will fit your SmartDisk. Most of the SmartDisk units use the mini USB plug. It is the same as many digital cameras use.
Tiger Direct, and MicroCenter also have many different adapters, and adapter kits to use on all kinds of USB devices.
I hope this helps. Please let me know if there are any more questions.
AAirwolf
PS: I use a 160GB SmartDisk on all of my Macs, and PCs. Get way to move data without conflicts.
Feb 13, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
My 40gb smardisk firelite usb connector has broken loose. I have files that i would like to have. There is another ext switch next to usb what is that and is that another way to get my files what type...
The other connector on the USB Firelite is for external power if needed. You will need to buy another 2.5" hard drive enclosure and pull the drive from the firelite and put it in the new one to get the files. Before you buy a new one open the firelite and take the drive with you to verify if it is an ide or sata drive. This will determine the type of enclosure you need. You could also take it to a local computer store and have them back the data up to dvd, but this can get expensive. You can typically get a new 2.5" ide enclosure for under twenty dollars.
Jan 22, 2010 | SmartDisk FireLite 80 GB Hard Drive
How do I purchase another usb cable for my firelite
USB cables are not specific to the product, so just go to any computer store or even Walmart and buy one, about $5
Jan 09, 2010 | SmartDisk FireLite 60 GB Hard Drive
Oct 08, 2009 | SmartDisk FireLite - 80GB - 5400rpm - USB...
Smartdisk Firelite 120 GB wont delete
Try to reformat the external hd thru the disk utility.
Sep 03, 2009 | SmartDisk FireLite USBFLB120 120 GB USB...
Firelite 30gig
Click on the link, or copy past the link, open the page scroll down and you will find Free Driver Download SmartDisk FireLite USB Driver Windows 98SE
this will work for win98 as well as 98SE (second edition) too.
http://www.opendrivers.com/driver/226844/smartdisk-firelite-usb-driver-windows-98se-free-download.html
Please let me know if it worked will be appreciated.
Regards
Moses
Jan 17, 2008 | FireLite (USBFLB80) Hard Drive
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
