Question about Porcher Round Front Toilet Seat with Chrome Hinges - 70010
Porcher toilet seat is loose on one side. How do I get to the nut within the toilet to tighten it?
I can get the seat off the hinges, but can't see how to access the nut to tighten.
  • 979 Answers
The nut is on the underside of the stool.
Posted on Jan 30, 2013
    New Friend:
Try this doc: https://www.plumbtile.com/mm5/pdfs/porcher/install/Install_4223.pdf
Posted on Feb 18, 2017
2 Suggested Answers
SOURCE: I have the porcher veneto
I too have the same toilet seat that needs replaced. Porcher just told me there is NO replacement seat that can be used and they no longer make nor have stock of this toilet seat. I have a local company looking into the problem and will get back to me. For now I am going to take detailed measurements of hinge placement and length/width etc, and take a tape measure to every home imporvement store in the area. Anyone with any other suggestion would be greatly appreciated.
Posted on Jul 15, 2011
How do i tighten soft close toilet seat on a porcher cygnet, with no underneath access to bolts.
There is usually a plastic nut that goes on the bottom and has a wing on it that will catch when you tighten the plastic bolt from above.
Feb 19, 2015 | Porcher Home
Trying to remove Porcher Posh BTW toilet. Screws in side of bottom unit do not "undo". They are loose but do not unscrew from base. I have loosened cistern but that is all - "loosen". Screws again undo but...
Removing toilet seat hardware can be a problem, especially as it is prone to corrosion - but it can be done. You can attach a pair of gripping pliers to the nut, apply thread lubricant, and unscrew the bolt from the top OR you can use one of those blade-and-handle hacksaws to cut off the nut OR you can use that little hacksaw to cut off enough excess bolt length to allow a socket to engage the nut and allow the bolt to be removed from the top.
Oct 31, 2013 | Porcher Home
I need a toilet seat replacement of Porcher Veneto Toilet. The part number is 70030-00-001 and I'm told by Porcher is no longer available. They say no other seat fits. Any ideas? Where to find
I had the same issue and basically called every single american standard distributor I could find. I finally found one! They had the gold hinges but I didnt care, it fits and works fine. Make sure you know the part number. I had a good salesperson that knew to look for any color hinge so I had a seat
Jan 08, 2013 | Porcher Toilet Seat Veneto 70030.071
Porcher Toilet Lid Hinges are loose
Tinkerbellpp is right about the 70032-00.001being out of stock. You can replace this with the 70030-00.001(chrome hinges) seat which will fit the Veneto Toilet. You can find this at your local dealer/showroom. Hope that helps!
Aug 29, 2012 | Porcher Toilet Seat Veneto 70032.001
I have the porcher veneto toilet. I'm looking to replace the seat/cover. Veneto Elongated Toilet Seat Cover, part no. 70030.00 (white with chrome hinges) Is there a compatible cover the will work...
May 23, 2011 | Porcher Toilet Onepiece Veneto ...
Not sure how to tighten or change toilet seat
First you want to reach underneath your toilet where the seat connects to it. You should see some sort of white nut. Just unscrew the nut from both sides. Once you're done with that pull off the old seat and place the new one on. Use the new nuts to tighten it down. For the most part you should be able to use your hand and not need any tools.
Apr 12, 2011 | Porcher Toilet Seat Veneto 70032.001
My toilet seat in not stationary any more- it has shifted-- can you help??? Connie
Connie the seat has become loose.
There are two nuts under the rim of the toilet, under the hinges of
the seat.
First line the seat up so it's straight, then tighten the nuts, just
tight enough so the seat doesn't shift any more.
Usually seat nuts are plastic and they have four tabs on them.
You can use a small pliers to turn the nuts.
I have a special socket for toilet seat nuts, that I can put on
a ratchet. But to tell you the truth, I have tightened seats 90
percent of the time with a pliers. I am too lazy to dig in my tool
box for the socket.
All my best and God Bless.
LeRoy
Oct 01, 2010 | Jacuzzi Refresh Bidet Set EV77
Porcher Round Front Toilet Seat with Chrome Hinges - 70010 Logo
2,765 people viewed this question
Top Porcher Home Experts
bobalix
ray gallant
Stan Ford
Are you a Porcher Home Expert? Answer questions, earn points and help others
