Question about SanDisk Sansa e200 MP3 Player
Computer can't see e250
I just got this 2 days ago brand new. When I plugged it up to the computer yesterday I think it shorted. The cd player that was running slowed down and the dial only had a faint glow. The "Sandisk" screen appears and nothing else. The computer doesn't see the device and even in recovery mode the firmware doesn't see it; its as if nothing is even connected. It works fine when not connected but obviously once the battery is dead I'm screwed. I have a ticket opened, but hopefully someone knows something.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
SOURCE:
How to get an MP3 player to work with my computer
when you plug ot to your computer does it recognize it? if yes all you have to do is copy some songs into it and that's all.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Sep 16, 2014 | RCA TH1101 MP3 Player
Has no instructions on how to upload music from pc
Hi,Ok, so, if you buy your mp3 players from the store or online and the device is brand new, you must have a box. Where is your new player, of course and some other important things. Those things are:
Installation CD, USB cable, earphones, recharger and maybe one or two more extras.
Installation CD - this is important, because its necessary for connection between MP3 player and Computer. This CD will help your Operating System to recognize the device. If you have Windows 2003 and above, maybe there is no need to install anything, but you still must have a CD in the box - in any case. For Example, Windows XP in 90% of cases will recognize your player automatically, when you have connected it with USB cable. This CD is also known as Driver CD or User Manual CD.
You must turn on your mp3 player and plug the cable with it. Then plug the other jack in to the computer. Now your device is connected to your PC. Now, if Windows recognizes the player automatically, messages will appear, like - "New Hardware Device Found" and "Hardware Installed and Ready to Use". In this case, when your mp3 player is installed, go to My Computer and look for the new icon, called "Removable Storage Device", or the icon may also be named with the name of you player. For Example: SciFlux Mp3 Player Device or something like that.
If windows cant recognize your player, then you must to use the Driver CD. Put it in the CD or DVD Drive. Usually this CD`s are with "autorun" feature. Just wait, do nothing and after few seconds the installing application will appear. Look at the possibilities. You must see something like "Install" or "Install Drivers" or something different, but very similar to "Install" or "Drivers". Follow the setup. Usually this process is short and easy, all you have to do is to click "Next" and "Finish" on the end. When you do this ... your player is now installed. And again - go to My Computer and look for the new icon - this is your mp3 player.
So, you have installed you mp3 player already. Your Player Storage device will be located in My Computer, like I say before. All you have to do now is to click on it twice. When the digital player is brand new, there will be nothing - empty. So, go to your hard drives, locate your music files. When you choose the music files you like to upload to the mp3 player, just copy them. Select -> Copy. Then go to Your mp3 player icon in My Computer ( the new icon, remember?), double click it ... and PASTE. Wait the copying process to complete and you are done. Now, switch OFF the USB cable and enjoy your music.
So, its ease, right?
Have a nice day.
Feb 18, 2011 | Audio Players & Recorders
My CD Player for a [Compaq] Presario V3000 hasn't been working. It worked fine less than a year ago, then it stopped working. My Computer doesn't show the CD icon any longer, not even Device Manager seems...
It will cost about $30 to buy a brand-new CD/DVD reader/writer.
Any computer-store technician can easily "manually" open your current drive, and remove the CD/DVD media.
Dec 14, 2010 | Compaq (120192-B21) CD-ROM Drive
I get the TOC Error, when I put bought cds in.
don't think you will like this answer but, it probably time to get a new cd player... you could try using a cd cleaner designed to clean the laser or spray the insides with compressed air.
Apr 29, 2010 | Kenwood KDC-MP228 CD Player
Cd will not eject
Return to place of purchase, sounds like the motor just dosent work. Its unfoutunate because their warranty dosent cover your time and effort
Jun 02, 2009 | Naxa Electronics NX-631 CD Player
Generic chinese mp3 player not recognized by computer
your MP3 player probably shorted. Try to drain the battery and charge it. Hopefully this solves the problem. If it doesn't your mp3 player is probably dead.
May 01, 2009 | Audio Players & Recorders
Pearl mp3 player malfunction.
I have a brand new (2008-2009) hp computer and can not figure out how to download music on it from a cd
Dec 16, 2007 | RCA Lyra RD2765 MP3 Player
Vgp-drwbx1 - DVD not recognised
If those are all the same batch and brand of dvd, try them in another computer and/or try a different brand in yours.
What software are you using for burning?
Oct 16, 2007 | Sony (VGPDRWBX1) DVD RW Dual Layer Burner
SanDisk Sansa e200 MP3 Player Logo
18 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
