Question about Husqvarna Garden
What is th biggest bar that a husqvarna 135 x torq can use
I bought a new 135 husqvarna and i was wondering can it work a bigger bar than the 14 inch bar that is already on it
dontbother10
  • 2220 Answers
SOURCE: How interchangeable are replacement chain bars for
Your question can't be answered as aked.
If your saw requires an Intenz 14" Bar it's Oregon pns 140SDET041 or 140GPET041. Part number 140SDEA041 if not Intenz.
Plug in your requirements here:
Oregon Bar & Chain Selector
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Once you get a part number it can easily be converted to other manufacturers numbers. HTH
Lou
Posted on Nov 03, 2009
lindsay836
  • 677 Answers
SOURCE: mccoulloch ms1436av 36 cc 14 inch bar looking to
http://www.buycheapr.com/us/result.jsp?ga=us2&q=mcculloch+chainsaws
Hope this helps
Posted on Feb 06, 2010
  • 4088 Answers
SOURCE: I HAVE A HOMELITE XL2 CHAINSAW WITH A 12 INCH BAR,
Usually, yes. Take the saw to a service dealer who can fit a longer bar and proper length chain. You will need to keep the chain properly sharpened and adjusted to prevent extra load on the engine. Hope this helps!
Posted on Aug 16, 2010
Testimonial: "Thanks for the comeback. I'll make sure to keep it sharp."
  • 2239 Answers
SOURCE: can i upsize my chain
There will be a 16" option, however things to remember, you will have a drop in power, so you need to keep the chain sharp, the oiling system will probably on its limit.
Posted on Apr 20, 2011
97F350diesel
  • 1326 Answers
SOURCE: how do I remove the bar cover on my new husqvarna 450 18 inch chainsaw?
Start with the fuse and if fuse is not blown check to make sure the CC circuit is actually turning on (cruise light when you arm the system) this will confirm you have power. If none of that backtrack to see where power stops. The CC is normally a vacuum controlled system so check under the hood an look for loose or disconnected vacuum lines to the CC unit.
Posted on Nov 10, 2011
What replacement bar is correct for the WEN 2400 14"
That would be a 14 inch bar with the size chain that you have. (5/32 or 3/16th) You can go smaller with the bar and get a smaller chain or you can go slightly bigger as well but the bigger it is the more power you need so don't over do it. This will cause too much stress on your motor.
Mar 15, 2016 | Garden
I have a husqvarna 350 chain saw and I want to buy a 13 in bar but they don't sell 350s no more and I was wondering if I can put a bar of a bigger engine
They do make what they call Log Wizard Guide Bars for this saw that are 12 inch. They aren't cheap but available. As for sharping, a good vise and a good file with a flat file and guide is all you need and the right angle, this takes practice. If you really need to use it take it and get it professionally sharpened.
Jan 07, 2015 | Husqvarna Garden
Why saw binds in middle of cut ?
check on which way you are cutting if what you are cutting has a load on it it could be pinching your bar
Oct 08, 2014 | Husqvarna 460 Rancher 20-inch 60.3cc...
What's the biggest bar i can put on a husqvarna 240?
The 240 origanaly had a .325 pitch chain and ran a 15" bar, it is not avisable to go any longer as the power loss will be great, the later machine had a 3/8 chain and ran a 14" bar, the loading on this smaller chain chain would allow you to fit the 16" bar, i think this will be the longest bar you can fit due to power and chain oil pump capacity
Jul 13, 2012 | Garden
Husqvarna 235 - not oiling- pulled oiler out checked oil flow from tank all OK. Assembled oil pump with inlet line full of oil and ran pump with coreless drill in both directions and no oil flow checked...
You cannot just rotate the pump shaft and expect it to pump, it has to have a throw, this is done by an acentric groove in the nylon pump gear working on a steel pin in the pump cover, the bigger the throw the more oil is pumped, the biggest problem with the early model was the oil went down the side of the bar and not onto the chain, there was a later delivery/pick up pipe to solve this.
Jul 05, 2011 | Husqvarna Garden
What is the biggest bar and chain i can use
The recommended length of bar for the 460 is 13 to 20 inches. I wouldn't go over the recommended length as it would put extra strain on the motor.
Dec 05, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
How interchangeable are replacement chain bars for older Husqvarna chainsaws? I've never replaced one before and was considering buying one from Sherril on-line which is on sale, a 14 inch Husqvarna Intenz...
Lou
Nov 03, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
97 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
