Question about Canon PIXMA MP600 all-In-One InkJet Printer
My printer is saying that it does not recognize one of my cartrid
It is my cynane blue & it has plenty of ink
  • Canon Master
  • 419 Answers
First thing to check is whether there's any soiling on the chip (eg: ink smear or similar). Try removing the cartridge and gently cleaning the chip with a bit of tissue and then replace it.
Otherwise if this an OEM (ie: Canon branded) cartridge, it's possible that the chip has been damaged and you can get a replacement from Canon.
However, you can save yourself problems in the future (as well as open the option for refilling) if you get a chip resetter (the most popular keyword is "redsetter") as this can actually reset problem chips and get them working.
Posted on Jan 23, 2009
After 7 yrs, suddenly the ********* cartridge is not recognized, no red light, why?
HP Officejet Pro 8500 will not recognize changed ink cartrid ...
h30434.www3.hp.com > Printers, Copiers, Scanners and Fax > Inkjet
Laptops & Tablets Laptops & Tablets .... HP Officejet Pro 8500 will not recognizechanged ink cartridge ..... I have a hard time believing that something that worked just fine until it ran out of ink, suddenly has a broken sensor. It's barely 2 yrs old. ... show any ink, replaced them all and after 5 minutes of 'thinking', ..it worked.
Epson cannot recognise a cartridge:16 ways to solve the ...? 6:33https://www.youtube.com/watch?v=bc04OM9ZRXkNov 4, 2013 - Uploaded by viandant5The red ink light remains on after replacing an ink cartridge. - The printer is not recognising one or more ink cartridges. ... Via Beverara 224/7 ... Printer cartridges not detected - How to fix - Duration: 2:41. by Thriftyink 102,951 ...Epson inkjet printer rejecting printer cartridges
Dec 21, 2015 | Office Equipment & Supplies
Ip 90 cannon cannot recognize color cartridge
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Nov 02, 2011 | Canon PIXMA iP90 Mobile Printer
Error 5...ink cartridge is not recognized after refilling
Clean the contact point of the cartridge to the printer before placing it, then **** some ink in the cartride by a cyringe to lessen the level of ink inside the cartridge. full ink cartridges encounter this error because the absorver inside the cartride overflows.
Mar 28, 2011 | Office Equipment & Supplies
I want easyshare photo printer COLOR CARTRIDGES.where do i get em
No. Simply use the paper when you get new color cartrides.
Jun 21, 2009 | Kodak EASYSHARE 300 Photo Printer
Since replacing 2 ink cartrides the printer doesn't work. The on/off light is flashing yellow
Have you tried unplugging the power cord from the back of the printer waiting a few seconds and plugging it back in. This may help it recognize the cartridges.
Apr 24, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Printer wont print the paper goes through the motion but no print
even when you change your ink sometimes you get dried up ink in the feeder lines take your ink cartridges out, take a damp cloth and wipe over the tiny holes were cartrides go, replace cartridges and press down several times firmly about 5-6 times on each cartridge that should start ink flowing
Nov 20, 2008 | Epson Stylus C46 InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
71 people viewed this question
old marine
old marine
