I can't seem to run Gmail with my acer aspire. I've seen this alleuded to in the past, attributed to the Macafee software. Any fixes?
    Problem Solver:
  • 17 Answers
Get rid of McAfee, either go with Norton or a free alternative like AVG.
Posted on Jan 23, 2009
Acer aspire overheating fix
What model of acer apire ?
When a laptop gets hot physically hot, to the touch you know something isn\'t quite right. It\'s normal for a computer to get a bit warm as it runs, which is why computers have a built-in cooling fan in addition to a heatsink and cooling vents. Excessive heat, however, is almost always an indication that something is malfunctioning. This is no different with the Acer Aspire 5000.
What\'s Happened If you\'ve ever looked inside of a computer or seen an "exploded view" of a laptop, you will know that thousands of components work together to ensure your computer\'s best performance. The cooling fan is activated by temperature readings from the central processing unit, which heats up and cools down depending on what it is being used for. Sitting idle, the temperature of the CPU will be low and the fan won\'t come on. When the computer is performing a few tasks simultaneously, the CPU is taxed and the fan kicks in. When you hear the fan whirling excessively, the computer is overheating which can damage the CPU. Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. b> Checking Temperatures You can download programs to monitor the core temperature of your CPU. Programs like Core Temp, Speed Fan or Motherboard Monitor use the hardware monitoring devices built into your Aspire notebook to track its core temperature. Different sources suggest that the Aspire 5000 can run at a different maximum temperatures. Users on Tech Support Forum say 50 to 60 degrees Celsius is normal even optimal and that above 75 degrees is a problem. Acer\'s technical manual for the Aspire talks about external temperatures for running the computer efficiently (between minus 20 and 30 degrees), but it says nothing of internal temperatures. A few different users reported overheating to the point of 90 degrees, at which point the computer freezes and shuts off. Warranty Fix Computer original equipment manufacturers like Acer sell every computer with a limited warranty. Overheating is usually covered by this warranty. If your computer is repeatedly reaching high temperatures, and you\'ve recorded the temperatures with software, contact Acer for a replacement or a repair. Out-of-Warranty Fix The simplest way to address an overheating problem is to let the computer breathe a little. Make sure that you use it on a flat, hard surface so that air can pass to the fan easily and without interruption. You can buy laptop cooling pads at most computer stores that are designed with this in mind. As a complex fix for an out-of-warranty system, you can follow a picture tutorial from MPS Computers to replace the sealant around the heatsink with a new glue called Arctic MX-2. This glue allows more heat to escape and brings the core temperatures down about 10 degrees. Acer Aspire Overheating issues http://www.techsupportforum.com/forums/f108/acer-aspire-overheating-issues-214199.html 257 software downloads results for "temperature"
b> Acer Support - ASP Login http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_AS3000_3500_5000_BOOK.pdf
Feb 26, 2013 | Acer Aspire Computers & Internet
Cant find webcam driver for acer aspire 4820t....pls help
i can't find acer crystal eye for Acer Aspire 4820t
Jan 26, 2012 | Acer Crystal Eye webcam
I keep getting a white blank screen on my Acer Aspire 4315. Sometimes on boot-up, other times while in the middle of a task. It is running Vista and has only 1GB of memory so I've ordered 2GB. Not sure...
A blank white screen generally indicates a video problem on a laptop. This can be a bad lcd data cable, a bad video driver, or an overheating/disconnecting video chip.
Oct 11, 2011 | Acer Aspire 4315 Notebook
My acer aspire 6920g battery has been worrying me for sometime now,the battery runs down minutes after i've taken it out of an outlet when it signals the battery is full.
How long have you had your laptop? Do use it more often on batteries? Your battery seems to be not holding a charge longer and is nearing its useful life if it as you said runs down just a few minutes. You might wanna think of replacing it or having it repacked. Good Day.
Sep 05, 2011 | Acer Aspire 6920 Notebook PC
How can activate my6 macafee anti virus
Instead of PAYING money to activate it, uninstall it.
Then, download FREE anti-virus software from: http://www.microsoft.com/security_essentials and install it.
Jul 20, 2010 | Acer Aspire One PC Notebook
I have an acer aspire one that is stuck on the start up screen showing acer empowering people and it wont go past that screen. iwas told it is a software issue. is there a simple fix for this?
Does it boot into safe mode (Tap F8 key on booting)
If so then a driver is responsible. Simply boot into safe mode and type msconfig into start / run.
Tick everything except antivirus / spyware program.Reboot and tick the box that pops up.
Mar 25, 2010 | Acer Aspire One PC Notebook
Acer aspire 3050
im fixing a simular model.. ive seen this sevral times in the last week.. to ONLY way i could get past this was to take the battery out the lappy for a few hours then try turning on again.. it worked for me
Apr 21, 2008 | Acer Aspire 3000 Notebook
How do you reset Acer Aspire T180-GB7Z PC
What do you mean, "Reset"? Do you mean like restart it or like reinstall windows with factory defaults?
Aug 18, 2007 | Acer Aspire 3680 Laptop
Problem can you cure plz :((
Not enough RAM memory. Increase the size of the Virtual[scratch] disc Reduce the number of different A/V- Spy ware programs These will conflict just use a single A/V and Firewall and leave it at that.
Jun 22, 2007 | Acer TravelMate 270XV Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
