Question about Waring WMK300 Professional Belgian Waffle Maker
Waring Pro WMK300
The mechanical stop has broken and now it rotates 360 degrees and doesn't operate properly. It no longer notifies you when the waffle is ready. I love this appliance but cannot afford to trash it and buy a new one. Can you help me by telling me where I can ship it to have it repaired (inexpensively????...please)...thanks for your help! I haven't had it very long when it happened but then I continue to try to use it even broken for a while longer.
Go to the manufacturers website and contact by phone
Posted on Jan 23, 2009
Diagram to replace thermal fuse in wmk 300 waring pro
The most common reason for thermal fuse failure is running the iron with the top open, especially when set to a higher number (longer cycle time) and/or not flipping the iron over at the strart of a cycle.
Keep it closed except during the 10-15 seconds needed when adding the batter or removing a waffle.
Thermal fuse 240C often available on ebay 4/$2 or Amazon 10/$7-$10
Feb 15, 2014 | Waring WMK300 Professional Belgian Waffle...
I need a replacement handle for my Waring WMK300 Professional Belgian waffle maker. Where can I get one?
If it is out of warranty, you will need to ask for parts from a service center.
No one is offering broken, used or as-is WMK300 on ebay. Maybe you should try to sell your waffle maker on ebay as parts. Somebody must need the circuit board, for example.
May 19, 2010 | Waring WMK300 Professional Belgian Waffle...
Unit has power light on but quit cooking waffles - not hot to touch
the heater element is not being powered....solution is to replace the thermal fuse which is in-line with the heater. the unit must be opened up, the fuse is usually hidden inside an high temperature insulating sleeve...cut the old fuse out, replace it with the same temperature rated fuse other wise, it will continue to blow fuses or the heater element may burn out completely....check the old fuse, if it says...90, then it is rated for 90 degrees celcius , must be replaced with the same cannot solder these fuses in...they must be crimped because the heat will melt the solder connection....if you can't do it...get a pro to do it for you
Aug 15, 2009 | Waring WMK300 Professional Belgian Waffle...
Will not heat.
There is a thermal fuse inside the bottom half of the unit, enclosed in a white insulating sleeve. This appears to be the weak part of the circuit. A replacement can be found here on
Aug 10, 2009 | Waring WMK300 Professional Belgian Waffle...
Waring Pro Waffle maker
Just spray the grids before each use with something like Pam, or put a thin coat of oil on them. I found it's better to spray before each waffle so it won't stick.
Feb 21, 2009 | Waring WMK300 Professional Belgian Waffle...
I need a replacement part for my belgian waffle made by waring pro... Model Number WMK300 The mechanical stop has broken. It will rotate 360 degrees and doesn't work properly anymore....can we replace a...
SHORT ANSWER IS NO . cheep made in CHINA no parts . be glad you handle did not break off , thats the common failure , another common one is the beeper stops working . and the ever fun- the wires wear through and when rotating sparks fly and flame shoots out ....... the chineese are going to kill us yet ...... good luck
Jan 23, 2009 | Waring WMK300 Professional Belgian Waffle...
Waffle Iron Handle Broken - Need Replacement
Go to the waring site, and look up the nearest dealer for repair and bring it to them. They should be able to contact waring for you and get you a replacement.
Sep 02, 2007 | Waring WMK300 Professional Belgian Waffle...
Waring WMK300 Professional Belgian Waffle Maker Logo
139 people viewed this question
Top Waring Kitchen Appliances - Others Experts
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
