Error code C-8104 KonicaMinolta - Office Equipment & Supplies
How to fix Error code C-8104 KonicaMinolta
The small (slit) glass that is to the left of the big glass under the document feeder, there is motor that moves the slit glass there might be a staple or something preventing that motor to move the glass as documents go bye trying to keep the glass clean. Reset in service mode. will prevent use of the document feeder, Might have a bad cable to that unit.
Jun 15, 2014 | Konica Minolta Bizhub C452 Color Copier,...
ERROR CODE CALIBRATING
Might require having the firmware up graded get a konicaminolta tech out to up grade the firm ware from a secure konicaminolta web site.
Jun 06, 2014 | Konica Minolta bizhub C351 All-In-One...
Errore f02 modello awoe 8104
open the bottom tray door on front panel 3 screws on bottom front.
clean out the trap
May 10, 2014 | Whirlpool Washing Machines
I have a KonicaMinolta Magicolor 3730DN. It fails with Fatal error code 0F55H.
Toner level sensor for the black toner is bad or the black toner is not getting into section where that sensor is. ensure your black toner cartridge is OK
Oct 05, 2012 | Minolta magicolor 2200 DeskLaser Printer
Prima ht 8104
Hello
What is the problem with your Prima HT 8104?
Mar 04, 2012 | Televison & Video
H11 error code , will not print more than 9 copies at a time
Do not have enough memory in the machine or the memory you have is going bad. recommend have a KonicaMinolta tech come out look at it, might be able to get a memory stick, maybe get more memory, you have a legacy Minolta machine, Now Konicaminolta. So try that.
Feb 03, 2012 | Minolta Di152 Laser Printer
Konica Minolta Magicolor5440DL Error Code
error 0094h = 2nd image transfer pressure/retraction failure
basically it means that either a sensor or cable is not fitted supposedly and reseating could possibly solve the issue.
you can research the error code in the following service manual:
http://printer.konicaminolta.com/drivers/other/Manuals/5400/smfs_54.pdf
Mar 09, 2010 | Konica Minolta magicolor 5440 DL Laser...
Error code 4703
What model? Because if your copier is Bizhub (KonicaMinolta) Error code 4703 means Main Unit G/A Communication Failure.
Aug 18, 2008 | Konica Office Equipment & Supplies
663 people viewed this question
k24674
jasbo
jasbo
