Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE3 seems to use way more than 10.5 gallons
Machine seems to be using more than 10.5 gallons per wash....at times is seems as though it is running our well dry....is there a water sensor to determine amount used??
Anyone else experiencing this issue??
  • 640 Answers
Well the water is meter by the unit ,,but i can give you the read outs,,large loads 12 - 14 gallons..medium loads 10 -11 1/2 gallons small loads 9..these are tech estim...it depend on clothing being wash,,,good luck onthejob
Posted on Jan 23, 2009
Washer capacity of kenmore 4906 4907 ie 5.0 cu feet
The Kenmore 592-4907 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
The Kenmore 592-4906 residential clothes washer is a front load washing machine. It has 3.69 cubic feet of volume, an expected energy use of 149 kilowatt hours (kWh) per year and an expected water use of 4773.384 gallons per year.
This is the Specs website despite the title :>)
teachmefinance com
Mar 24, 2017 | Kenmore Washing Machines
What setting of hardness number should i set if i have 8 grains per gallon
If there is only hardness (calcium/magnesium) and NO iron you can set the hardness at 8. It is best to round up though to 10. This sets the amount of gallons before regeneration and lbs of salt per regeneration.
RJH2O
Feb 20, 2013 | Washing Machines
Sud error on Kenmore Washing Machine HE3 King Size
The SUDS or SUD error can be caused by too much detergent, improper detergent, drain pump/drain line problem, or pressure switch malfunction.
1. If you are not using HE detergent, you need to be. These washers are designed to use HE detergent which is formulated for wash tubs that use 5 to 7 gallons of water. If you use regular detergent, you are, in affect, placing a higher concentration of detergent in the washer that is normally formulated for wash tubs that have a 35 gallon capacity. The manufacturer should have a disclaimer in the owner's manual explaining this. In most cases this will also void your warranty. NOTE: Prolonged use of the wrong detergent can damage the drain pump components and or wash tub seals.
If you are using the correct detergent, double check the label to make sure it is not double (2X) or triple (3X) concentrated. You could still be placing too much soap in your wash.
To get rid of excessive detergent, place the washer on a RINSE & SPIN cycle, then run it through a normal wash cycle with NO detergent added. You may have to repeat these steps depending on the amount of detergent used.
2. If you do not have a detergent issue, double check the drain pump and drain lines to ensure they are not obstructed in any way. Click on the following link for step-by-step instructions:
CLICK
Oct 29, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore he3 washer is about 10 years old and the first generation. It is leaving oily stains on the clothes, how can I fix this?
This is from not enough HOT loads.
Fatty deposits gather between the basket and tub during COLD washes.
Then they are being released in large numbers when you do your whites on HOT.
It is recommended to do 1 HOT load per week.
Do an empty load with some degreaser added (like Goo-Gone) on the fullest/hottest setting you have.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Wter usage per load/cycle
When set on large load, it will use close to 30 gallons of water. On the smallest load setting, it will use right around 20 gallons. This is what makes the new front load washers look so good. They average around 4 - 6 gallons per load. Have a great day.
Oct 18, 2009 | Kenmore Washing Machines
Front Load Washing Machine Filling On It's Own
the inlet valves are shot. what happens the coils in the inlet vales can no longer hold the water from going into the unit, causing water to run into unit when not in use. replace the inlet valves and you should be good to go. the inlet valves can be removed by, removing top panel(3screws in back), disconnecting hoses, taking the small clamp on the small hose connected to the dispenser. theirs a small screw holding the inlet valves from back pane, remove old inlet valves and replace and you should be all set. hope it helps.
Apr 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Should I see water in my machine when it is washing?
may see some but not much..front loads only use 4-6 gallons and is adj as water is absorbed by clothes ..a typical top load will use 25 gallons or more per fill thats 50-55 gallons per wash verses 25-30 for front loads also you should see very few suds ..be sure to use HE detergents to prevent oversudsing
Aug 20, 2008 | Kenmore Elite 45986 Front Load Washer
Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Mar 09, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
