Question about MSI K8N Neo4-F Motherboard
K8N NEO4 Hi, My system was working perfectly, but when I change the cpu casing it is now not working. When I switch on the power button processor fan is working but there is no display. I dont know either is power supply problem or my connection problem. please help
  • sohailp Jan 23, 2009
    sorry i can not understand what to do. please clarify. thanks
    Sergeant:
    Champion:
  • 242 Answers
Cpu casing? What is that? To test the power supply, just use a paper clip in the ATX connector on the green wire, and the black wire next to it. Make sure everything that is hooked up to the power plugs, is unplugged. That should tell you if its the power supply.
Posted on Jan 23, 2009
Is not started computer
first you cheak power supply working or not is that working so moterboard give power supply and cheak cpu fan working or not is not working then you replace your motherboard.
Mar 29, 2010 | MSI K8N Neo4-F Motherboard
MSI mobo powers up, but no signal to monitor.
i hate to tell you this but it seems your pci or in your case agp exp.slot is most likely melfunctioning if your card works on another computer then that may be your problem one thing you can try is take the mobo out and let it sit for a few days or call msi them selves and they may replace it for you for free they are good about that i have the k8n neo4 with a 7950 1g pci.e with same problem and thats my pci e not working
Mar 15, 2010 | MSI K8N Neo4-F Motherboard
CPU wird überlastet , System sehr langsam
just replace bios battery and youre probleme will be solved
Mar 09, 2010 | MSI K8N Neo4-F Motherboard
About MSI K8N Neo4
http://www.fixya.com/support/p298028-msi_k8n_neo4_f_motherboard/manual-15408
Sep 14, 2009 | MSI K8N Neo4-F Motherboard
Replace motherboard
There is no need to get an exact replacement motherboard, most likely it is out of production if it is more than 6 months old.
The desktop case has and motherboards have standard configuration mounting holes. I sugest you work out what your computing requirements are and go to your friendly computer shop and purchase a motherboard.
Most of the existing components will be compatible but the RAM and CPU may not, you need to check this out.
Sep 10, 2009 | MSI K8N SLI Platinum Motherboard
Fan does not come on mobo & Fan on video card making a noise
There are many sensitive parts inside your CPU that can be destroyed by simply opening your box/chassis.
*If you are not confident that you can safely open the casing, then you should seek assistance from a qualified technician.
Remove the power cables before proceeding!
The first step in checking to see if your CPU fan is working is to remove the case cover, normally secured with screws at the back.
Most common chassis covers will slide out after the screws are removed.
*Make sure that you maintain contact with the metal part of the chassis to avoid causing ESD damage to your CPU/internals.
Next step, re-attach the power cable and avoid touching the metal chassis this time (there is a risk of shock) before you power on. You should see the fan moving at this point, if it is still working.
Fan not moving? You can take that small paint brush and very carefully run the brush along the fan blades to clear them of dust bunnies. This could also get your fan to run again. It is an immediate solution, but not long term.
It is more adviseable to replace the fan if it siezes or stops working.
Hope this helps.
Jun 23, 2009 | MSI K8N Neo4 Platinum/SLI Motherboard
Cpu and cpu cooler
Yep the cooler will work with your athlon processor.
~gnomer
Jan 31, 2009 | AMD Athlon 64 3500+ Processor (castle)...
NX7800GTX-VT2D256E and MSI K8N Neo4/SLI
What's the specs on your power supply. For SLI you need a good quality 500W+ PSU with lots of current on the 12V rails. Remember that all the drives, memory, fans, cpu, etc will use a lot of power, if there is not enough capability in your PSU, the voltage may drop low enough to stop it starting up.
Nov 22, 2007 | MSI NX7800GTX-VT2D256E Lite GeForce...
Cpu fan stopps
try to clear cmos with the jumper next to the mainboard battery
hit delete enter setup bios and save changes
chek if the main board is not in unapropriate contact with the metal case.
chek the fans power connector pins in the board
and finally make sure that ur power supply is functionong properly.
Nov 14, 2007 | Computers & Internet
MSI K8N Neo4-F Motherboard Logo
97 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
