Question about Refrigerators
GE GSD6610k00ww problems - Refrigerators
The insulation in wall between the refrigerator and freezer is frozen and deemed unrepairable by GE. Is this a frequent problem?
I worked for GE for over 25 years and never heard of that . What exactly is the problem?? Was this told to you by a factory GE tech or an independent service company? GE has a very good Customer Relations Dept to handle problems like this. In your situation they might offer you money off a replacement for a non repairable item or pro rate it somehow if the story is correct. Should be an 800 number to call in your owners book or contact a local GE dealer for the number. Anything is possible but this doesn't sound right to me.
Feb 16, 2015 | GE Profile PSH25MSS 36" Arctica...
Uniden survaillence system will not pair with this camera but says it will pair with any wireless camera. How do I pair the GE with Uniden
I am not aware that Uniden survellience systems pair with cameras other than a Uniden camera. Please provide model number of your Uniden system to help with a solution to your problem.
I understand that GE Add-On Wireless Digital Color Camera 45256 will work only with a GE security system like Ge 45255
Apr 27, 2014 | GE Add-On Wireless Digital Color Camera...
How do I program ge timer where can I find a ge
GE timer manuals:
http://www.jascoproducts.com/support/manual-downloads/index.asp
Open link and enter 'Timer' in keyword search
There are 2 pages of GE timer manuals.
In a few years these manuals will not be listed, so save the pdf manual for your timer.
Add a comment if you have problems.
Nov 20, 2010 | Whirlpool Hardware & Accessories
Are replacement decals available for the heat settings around the stove knobs?
I Just called GE about this problem, wanna know their answer???
Replace the whole stainless stell cook top piece for $325 ! ! !
Customer Service, at its finest.
This is obviously a GE problem , i live in a neighborhood of recently constructed homes, all of which have the same GE appliances, and all my neighbors are having the same issues.
Gee, thanks GE
Aug 14, 2010 | GE 30 in.JGP330 Gas Cooktop
Ge advantium 120 powered off after a few minutes
I would call GE and explain the problem It may be a glitch in that model they may be able to give you the solution
Dec 29, 2009 | GE Advantium 120 Convection/Microwave Oven
My spacesaver dated September of 2004 shuts off
I solved the problem by buying a new microwave and it was not a GE. I feel that GE should have had a recall on this problem, since it seemed to be a major problem in their system. I will never buy another GE product.
Oct 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Aug 07, 2009 | GE PDS22LBN Bottom Freezer French Door...
Howling wind sound from the freezer/ice maker (extremely loud)
check the model # you post cannot find match there is a fan in the refrigerator section that some times make noise
Mar 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile JGSP32GEV3BB slide in range - regulator went bad #WB19K5020
"GE makes garbage" that's what a lot of independent servicers says about brands they can't become authorized to work on because GE for instance has factory service. What makes the repairman think the regulator is bad? It is highly unlikely to be the case.
May 12, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
