I have a 05 jvc tv 32 inch . I lost my remote temporarily-used the menu on the actual TV to set a timer for the TV to go OFF-turned it on this AM and now i have half of my screen filled with this overlay . its kind of transparent . like the screen that comes up for tv controls , but its just black . i change channels and it goes away for two seconds then its back covering the bottom half of my screen-
I have a JVC AV-32WF35 ~ 2004 model that is cutting off about 3 inches of the screen on both sides. Ive looked at all of the menu options and none of them seem to be any option to fix the picture width. Any sollutions?
Posted on Sep 02, 2009
  • 716 Answers
Try Reseting It Unplug It For 30 Seconds And Then Release And Plug It Back In Once You Go To Turn It On Hold The On/off For 10 Seconds and Then Release. This Will Hopefully Restore The Factory Setting And You Can Determine If Its A User Setting Or Hardware Problem.
Posted on Jan 23, 2009
I need to know the service mode of JVC TV flat screen
With TV powered ON press: [DISPLAY] and [VIDEO STATUS] on the remote at the same time.
-or- Press the [SLEEP TIMER] key and set the SLEEP TIMER for "0" MIN. While the SLEEP TIMER information is still on screen, press the [DISPLAY] key and [VIDEO STATUS] key of the remote control unit at the same time to enter the SERVICE MENU.
Exit the service menu by twice pressing the [EXIT] key on the remote.
Mar 18, 2011 | JVC AV-32S575 32" TV
My JVC AV-32820 is locked and I do not know the code to unlock it. Is there a general default code that I can use to unlock my t.v.?
How can i unlock my jvc av 32820 it turns on but is locked in one channel and i do not have the remote that came with the set can i use my cox remote to set the menu on tv
Dec 25, 2010 | JVC AV-32820 32" TV
Digital input not working and greyed out on the menu.
Most JVC TV's with HDMI and Digital Input have an optical sensor inside the case to sense if someone is trying to bypass the hardware encryption. My JVC was exposed to sunlight prolonged sunlight and triggered this optical sensor which disabled my HDMI ports. This may be the same situation for you.
JVC HDMI Port Fix
Turn the TV on, and enter the Service Menu. Select 2 for Self Check. Then turn the TV off, and after the fan turns off, unplug the power cord. Reconnect the power cord, turn the TV on, and the HDMI port is re-enabled.
Here's how to get to Service Menu:
Before entering the SERVICE MENU, confirm that the setting
of TV/CATV SW of the REMOTE CONTROL UNIT is at the
"TV" side and the setting of VCR/DVD SW of the REMOTE
CONTROL UNIT is at the "VCR" side. If the switches have not
been properly set, you cannot enter the SERVICE MENU.
1) Press [SLEEP TIMER] key and while the indication of
SLEEP TIMER 0 MIN is being displayed, press
[DISPLAY] key and [VIDEO STATUS] key (Fig.2)
simultaneously.
2) The SERVICE MENU screen of Fig.1 is displayed.
3) Verify what to set in the SERVICE MENU, and set
whatever is necessary (Fig.1).
Refer to the SERVICE ADJUSTMENT for setting.
4) Press the [BACK] key to return the SERVICE MENU.
Dec 12, 2010 | JVC AV-56WP74 56" Rear Projection...
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I have lost the remote and i cant get to tune in the channels, JVC AV-36D303 36" TV
use the button on the actual TV itself, they will do most of what the remote will do, you have menu, left, right, up down, enter./set, ON?OFF. They WILL be there somewhere...
May 02, 2010 | JVC AV-36D303 36" TV
The TV shuts off automatically and the Timer On button on the front of the TV flashes. The TV will not start again, either manually on the TV or with the remote. If we unplug the TV, leave it off for a few...
sound like timer setting on . you need to go to setup menu the timer set it off, if not , you need to check power supply unit, high value capacitor if under reading replace it. good luck!
Jan 27, 2010 | JVC AV-32230 32" TV
Can not turn on tv.
Just press the buttons on the TV randomly, sometimes this combination works in starting the TV w/o a remote. After that use the remote for the dish to flip channels, but you will have to set the sound manually from time to time.......sodeep
Jun 13, 2009 | JVC AV-32120 32" TV
Can't play dvd player on JVC tv; I don't have a JVC remote.
I hooked up a Pioneer DVD player to my TV and when I play a DVD the volume cannot be controlled by the TV. It just plays at one level and on the louder side. When I'm watching regular TV and the DVD player is on and playing a disc I start to hear the DVD soundtrack at the same time as the whatever I'm watching on TV. I should not be able to hear anything until I switch over to Video 1. Any suggestions?
Dec 31, 2008 | JVC AV-32F476 32 in. Television
JVC TV AV-32870 will not turn on. blinking timer light
Worth taking it in since it is hard to find a new TV for less than $300. I have a 32 inch JVC iart that for about 2 years would turn itself off and the timer light would blink. Only thing that worked would be to disconnect and turn back on. Eventually, the tv "popped" I could smell something that burned out and within 3 weeks tv went "dead" Took it to a tv repair place and replaced power unit for $150. I had similar problem with a 19 inch Philips and that tv has been going strong for 4 years since repair.
Good Luck
Oct 17, 2008 | JVC AV-32820 32" TV
My JVC TV Problem
hi.. sir
if universal remote does not work properly.. i am not sure
just open the tv and see if any cmos battery is inserted .. in circuit board.. if any present.. answer me sir..
Sep 01, 2008 | JVC AV-27D302 27" TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
