Question about PEAK 12 Pkc0tm 1 Million Candlepower Cordless Rechargeable Spotlight Flashlight
Dose not light up i have changed the bulbe old bulbe still ;looked good
Change bulb on 6085 PFAFF
Looks like you bulb is a bayonet style. Push up and rotate the old bulb to remove. Install the new bulb the same way--push up & rotate to lock in place.
Note: there is also a bulb remover tool
Pfaff Varimatic 6085 Parts
PFAFF fashion Owner Manual Changing The Light Bulb
Apr 07, 2017 | PfaFF Sewing Machines
1992 Nissan D21 , left turn signal dose not work , changed bulb and relay , still dose nor work. What next?
Next is probably the turn signal switch. If you have a voltmeter, however, you could be more likely to find the problem, using it to test for voltage at places in the circuit. So I guess you might also need a wiring diagram along with the voltmeter...
If you have neither a voltmeter or a wiring diagram, use logic to think the right turn works so the fuse is good, and if the right turn works, power is going to the switch, and out correctly for the right side, but seems nothing for the left, ( DID YOU CHECK NOT EVEN A BULB DIMLY LIT ON THE LEFT SIDE, FRONT OR BACK? AND ALSO THE LEFT TURN DASH INDICATOR IS NOT LIT?) If nothing lights up for left side, the power is probably lost right in the 25 year old turn switch. That's where you would check for power out (on the proper wires) with a voltmeter- no power means switch is bad. But if the power comes out of the turn switch for left side, then you have to look further along in the wiring , probably not far from the switch connector if the dash indicator bulb is also not lit....It probably is your turn switch.
Nov 25, 2016 | Nissan Cars & Trucks
My left reverse light don't work but my right one dose how did I fix my left one
Check the bulb by swapping with another bulb and the negative earth cable has a good contact. Does the park light and brake light work properly on that side?
Apr 11, 2016 | 1998 Holden VT Commodore
Headlights went out.Everything else works dose not look like a bulb or fuse. what can it be?
If it's not a fuse or the bulbs (and if both went out at the same time, that would seldom be bulbs, anyway), I would suspect it to be a fault in the headlight switch, itself. That's where I would look first, anyway.
Aug 25, 2015 | Cars & Trucks
I change my bathroom vent light. Before light went out. When I would turn the light on. It just came on. Now with new light, it flickers then comes on. And my hall bathroom started doing it too once I...
It sounds like you have indeed bought fluorescent bulbs. manufacturers are encouraged to replace the incandescent bulbs with more energy saving fluorescent bulbs. They are made to look like standard bulbs so you need to look at the package carefully to see the difference. The Nu Tone and other special bulbs may still be available in the old filament style for a while but you may have to look harder or ask if they are still available. The amount of flicker often reflects the quality of the bulb. It will sometimes decrease over time.
Mar 02, 2015 | Dryers
No light in door dispenser
The light bulb is located in the top panel just above the dispenser and to the front. Be sure to check the manual for bulb voltage, most of these used a 12 volt bulb and NOT a 115 volt. It looks like an old style small base Christmas tree bulb.
Mar 21, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
When i put D drive (automatic Gear) the D led in Dash dose not light.
have the combination meter changed if its using LED type of bulb.if its a normal bulb ,change the bulb.
Apr 28, 2010 | 2001 Kia Sportage
CHANGED BULB IN TAIL LIGHT STILL DOESN'T WORK
if it is only one side that does not work and the bulb is good then it is probably a bad light socket or a bad ground wire. if both tail lights are out then it is more likely to be a fuse or a bad relay.
Feb 12, 2010 | 2003 Ford Explorer
How do i change out the head light
Unlike the cars and trucks of the good ole days, todays headlights are simply, bulbs inserted into the back of the lights... generally installed with just a quarter turn. All the plastic is nothing more that a "light fixture".
Pop the hood and look at the back side of your healight. Remove the bulb connector (counter clockwise twist) to get the bulb out.
You should be able to get a replacement bulb at Walmarts... take your old bulb with you to insure you get the right one. It should install as easily as it was removed.
Hope this helps... Good luck!
Oct 12, 2009 | 2005 Chevrolet TrailBlazer
2007 Forrester - headlight bulb good but not lighting
You will need to look at the plug for the headlight. If it looks good, I would look for the headlight low beam fuse.
Mar 05, 2009 | 2007 Subaru Forester 2.5X L.L. Bean...
PEAK 12 Pkc0tm 1 Million Candlepower Cordless Rechargeable Spotlight Flashlight Logo
Top PEAK Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a PEAK Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
