Question about Motorola Mobility HS850 Consumer Headset
My N136 / HS850 Bluetooth
1. How do I turn it off?
2. How come it won't go into dicovery mode?
3. It was given to me but it has a lock on it and the person doesn't remember the code. How do I unlock it?
  • dlw_1990 Jan 23, 2009
    I've never seen this exact bluetooth's light turn red, ever!
  • 716 Answers
Push once to turn it on, push it once to turn it off if its in the on mode,
hold power till it flashes red,blue over and over then its in discovery mode and all zeros is most likely the code for it.
Posted on Jan 23, 2009
  • Michael Fisher
    Michael Fisher Jan 23, 2009
    Ok Close The Headset Boom And Hold The Multifuntion button until the headset indicator turns on then release and open the boom. Then its On Discovery Mode And I Have Confirmed The Code Is 0000. Pairing Is Successful when the indicator on the headset flashes 10 times. On steady is pairing mode also you wanted to know how to turn it off well it turns off after 5 minutes of not being used And Will Turn On With The Touch Of The Button.
    Also Click Here For Your Manual
    Please Rate Our Experts
    Thanks For Using Fixya.com
    Sincerely,
    Michael Scott
Motorola hs850 bluetooth headset won't pair with g five mobile
How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
  4. (Now you can let go of the call button.)
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
May 14, 2012 | Motorola Mobility HS850 Consumer Headset
My motorola n136 will not pair to my ps3
Hold down the answer call button on the bluetooth headset until the light is solid (not flashing). When the PS3 detects your headset, it'll ask for a pass. The pass should be "0000" (four zeros).
Hope this helps.
Oct 20, 2011 | Motorola Mobility HS850 Consumer Headset
Hi, I have an bluetooth n136 hs850 and it is turned on and blinks ,but i cant get it in descoverble mode, it wont stay blue keeps blinking, can youtell me how to get it in discoverable mode? thankyou
close flap (off mode) hold down the "on" function button until the blue light comes on. once it comes on open the flap.. the blue light should stay on. you should already have your phone set for pairing. if your phone ask for a password. its generally 0000..but heres a link to the guide..http://direct.motorola.com/hellomoto/motosupport/source/generalpairinginstructions.asp?p_headset=742
Sep 30, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Motorola device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Season's Greetings from Fixya!
Chris (ziraffa)
Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
How to connect the bluetooth??
I used this Motorola Bluetooth manual to connect my Motorola N136/HS 850 to my LG PM 325 phone. In the attached manual: Go to "using your headset" - "linking your headset and phone" and follow the instructions. You may need to revise the steps slightly to fit the functions of your phone. I followed steps 1 and 2, skipped step 3 and instead found the bluetooth icon on my phone, selected "add new", then selected "searching and pairing" and allowed the phone to search for and pair my bluetooth device. The Motorola Bluetooth device appeared on the screen of my phone within seconds as "Motorola HS850". I selected the device on the screen of my phone and followed step 5 entering the pin code "0000" and selected "connect" on my phone to begin using my bluetooth. I hope this helps someone. Use the following link to access the manual: http://www.usersmanualguide.com/motorola/accessories/bluetooth_wireless_headset
Aug 05, 2008 | Motorola Mobility Bluetooth Hands-Free...
Lost N136 Manual
I have an N136 which turns out to be an HS850 (with folding boom}. This model requires the boom to be folded while the answer button is held down, When the light comes on the boom must be extended before the light goes out. The light will now stay on and the phone should find your headset.
Jul 31, 2008 | Motorola Mobility HS850 Consumer Headset
I have a Motorola N136 hands-free ear piece and cannot get it to sync with my Blackberry. I need some help.
It's not actually an N136. It's an HS850.
To pair it, turn bluetooth on the blackberry on.
Close the mic on the headset.
Hold down the headset button until it lights up.
Open the mic on the headset.
Tell the blackberry to search for devices.
You should be back in business.
Jun 17, 2008 | Cell Phones
Motorola Mobility HS850 Consumer Headset Logo
255 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
