FixYa.com
Tags:
Office Depot Ativa  DQ60M Shredder
Wont stop running (by 2 users)
posted by hottotrot on Jul 06, 2007
i turn the power switch to auto and it turns on right away. i have shaken it, banged it and it wont stop.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by bill20124, posted on Feb 27, 2008
This is an annoying problem. I have disassembled the shredder and cleaned out the jammed paper. This provided a brief solution. Banging it hard will sometimes stop the incessant running. I haven't tried filing down the plastic sensor. I have concluded it is basically a low quality product.
Best Solution
posted on Jul 06, 2007
Thanks for Trying (70)
CompuGuy44
Rank:Wiz Wiz
Rating: 83%, 708 votes
The auto switch is stuck. Feed more paper in it to clear it, and kick once for me. The shredder has a paper jam. You can try 3 or more sheets at one time to clear it. Also try 'paper shred oil'. You can buy it at Office Depot or Office Max.
Rating Locked! (?) hottotrot has rated this solution as Thanks for Trying
Solution #2
posted on Feb 20, 2008
Not Rated (0)
dkusleika
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
My Ativa DQ80M would run for about 2 minutes after it was done shredding. I cleaned it out thoroughly to no avail. Then I took the whole thing apart down to the activator switch. I was looking for an optical sensor (it doesn't have one).
Inserted paper moves a small plastic piece. This piece squishes a small plastic diaphragm which activates the ON switch. As the diaphragm returns to its original size, the ON switch is deactivated and it stops running. I think the plastic diaphragm is old and just not as "springy" as it once was, so it takes considerably longer to return to its original size.
To fix, I filed down the hard plastic piece (the one that paper moves and which squishes the diaphragm). I estimate that I took off a couple of millimeters. Actually I took a little off, put it back together, took it apart, and took off more.
I took off the five screws on the bottom (probably voiding the warrant), removed the plastic cover, removed the blade roller mechanism (just lifts out, no screws). Then I removed two screws to remove the plastic switch housing. The hard plastic piece lifts right out to be filed.
The end result is that the diaphragm isn't compressed as much and doesn't need as much time to return to normal shape.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on Aug 19, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Mine wouldn't stop either. Removing the shredder head off the wastebasket and looking at the shredding teeth revealed the problem. The teeth were mangled and severely bent and overlapping one another in the center of the teeth-bar. Paper was compacted in that area and the build-up made the shredder to run continuously when the power switch was on. I have the Activa DQ61BA from Office Depot. It has been used maybe 20 times at a seasonal lake home (really sparse use). It has shredded maybe 1 credit card and 10 staples on paper (which it is claimed to be ok). Since the problem is in the center of the teeth-bar, it must have been the one credit card that destroyed the cutting teeth--or else just bad design.....So much for Activa....
Can you Help with these Shredders problems?
Staples SPL-1506X
Paper jammed, I cleared the jam... Answer This...
SPL-1506x issues
Hi We have had this product for... Answer This...
Staples SPL-1506X Shredder...
My bin full light is on when... Answer This...
Overload
How do you correct an overload... Answer This...
ativa DXC180D
after lubricating the shredder... Answer This...
Repair Service
Find Shredder Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
