Question about Toys
My predator ignite helicopter won't lift
Rd helicopter won't lift
3 Suggested Answers
Don3542
SOURCE: My helicopter won't take off,
This issue is the "Drive Gear Unit" It is the small gear just above the motors which is attached to the very large gear. You will have seen several posts indicating that sometimes this gear shifts and does not engage the larger gear. In my case I looked and say that it was indeed trying to engage the larger gear, however the gear is stripped (the teeth are nearly gone). The sound that you are hearing is the sound of the gear slipping against the Bigger gear. I have a UJ365 which is a newer model. To my disappointment I cannot find a "Drive Gear Unit" anywhere on line. The copter will not function without it. This issue is that it takes the lift of both rotors to lift the copter into the air. There are two motors (one for each rotor) and each motor has one of these drive gear units. Each of these attach to the larger gears which turn the rotors. The rotors each turn in the opposite direction. This is what keeps the copter from continually turning in one direction. When one of the "main Gear Units" becomes damaged it seems to have three noticeable effects. (1) There is a noise that is the gear grinding against the bigger gear. (2) Because many of the teeth are stripped the drive gear engages the bigger bear only some of the time, this causes the rotor to turn slower and in-turn causes there not to be enough lift from the rotors to lift the copter. And finally (3), someone noted that copter wants to spin in one direction. Understanding the above, you can now understand that if one of the rotors is not reaching its full potential to turn, it is also not reaching its full potential to counter act the other fully functioning rotor. Thus the fully functioning rotor is forcing the copter to spin in its direction and the malfunctioning rotor is not spinning fast enough to stop the spin.
So this is the answer to your questions, hopefully on the older models there will be parts available for you to replace it. The copter cannot work until the part is replaced.
Posted on Jul 11, 2011
bayyagg
  • 1672 Answers
SOURCE: my green air hog helicopter
There is a problem on the motor gear, check the underside where you could see a big gear that should spin when you try to lift the helicopter. Check both big gears if they rotate/spins.
Usually the problem is the small gear on the motor shaft that is not aligned to that big gear. Check on it and adjust the small gear of the motor.
Hope that copter flies high.
Thanks for asking FixYa!
Posted on Aug 09, 2011
Where can I buy a tail rotor motor for my protocol sb 3.5 channel
You can order here. https://www.shopprotocol.com/spareparts/tail-rotor-and-pinion-gear-predator.html
Mar 07, 2014 | Protocol Predator SB 3.5-Channel...
My helicopters tail bends down just a little, starting just past where the support beams and tail connect.
I have added a quarter to the tip of my dh9118 and slid the battery a bit forward to give it a center like balnce
Mar 01, 2014 | Protocol Predator SB 3.5-Channel...
Hi there I've got a 05 polaris predator 500 Tory
hi try cleaning the carb or check your air filter box might be filled with oil so all you have to do is clean the air filter out with water let it dry and soak all the oil up with a rag or sponge. Best of luck!
Aug 28, 2013 | Garden
My micro twister pro helicopter won,t lift off. all seems to be working fine
If it was the motor gear, the blades wouldnt be turning at all...some ppl are clueless :-/
Jan 03, 2012 | Toys
My green air hog helicopter is spinning on the ground, it won't lift and fly, how do I fix it?
Aug 09, 2011 | Air Hogs Havoc Heli Helicopters
Can you use the iomega predator cd-rw with windows 7?
It is possible but you won't get the full functionality of it.
May 18, 2011 | Iomega Predator CD-RW Burner
Toys Logo
Top Toys Experts
Tom Chichester
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
