Question about HP PSC 2355 All-In-One InkJet Printer
Hp 2350 printer error code 0x83b4a0e0
Error code 0x83b4a0x0
Will a hp2350 all in one printer work on windows 7
Yes, but...
There is not a full feature driver for it. You will need to go to:
PSC 2350 W/Windows 7
Follow the instructions outlined. There are some work-around procedures for scanning, faxing, etc. at the bottom.
I would check back to the HP support site occasionally to see if new software is available.
http://welcome.hp.com/country/us/en/support.html
Thanks for using Fixya.
Dec 02, 2009 | HP PSC 2350 All-In-One InkJet Printer
How can i repair error 2350 with no cost?
The Windows Error 2350 occurs when the installed version of the Windows Installer is too old for the MSI to execute. The registration entry for the engine has been damaged and all attempts to execute the MSI installation packages will not be successful.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
To fix the registration entry for the Windows Installer, the Installer service should first be registered then unregistered using msiexec /unregister and msiexec /regserver or the command line switches. The user will then have to restart Windows
Oct 31, 2009 | Microsoft Windows Vista Home Premium with...
Error load paper?? but already have paper!!
what i might do is to remove that application using control panel, add and remove software. uninstall the printer software disconnect printer from pc, reboot/restart, go to printers in control panel remove all printers listed, then make sure you have right software for your printer. shut down this time.reconnect printer cable and boot back up. reinstall the soft ware with printer on.
Aug 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
Paper doesnt feed
please try to clean rubber rollers that pickup the paper but didn't...
Mar 31, 2009 | HP PSC 2350 All-In-One InkJet Printer
My 2350 all in one will not turn on.
I'm not sure if this is a solution, but it worked for me. ( who knows how long it will last, but its working for now)
Below are the steps I took:
- uninstalled all the HP drives and software
- unplugged the USB cable from the computer and printer
-unplugged power supply from the outlet and printer
-plugged the USB back in to computer and printer
-unplugged the power supply from the power module. Made sure everything looked ok,
-reattached power supply cord to module ( Made sure everything looked ok,)
-plugged power supply in to outlet ( green light was on)
-proceeded to plug power module connector to printer. ( again, making sure proper connection was made.
* this time the screen came with an error and the "on" power light was blinking.:
This was the error message:
Error:
0xb9000009165:
hw_interupt_hwv.c
-I proceeded to unplug the power and usb from the printer
-downloaded the lastest drivers and software for the PSC 2350
-After the software was loaded and installed ( I checked the box to install with out USB communication at this point)
- plugged the power and then the USB.
-It came to life at that point. (the computer recognized the "new" product)Going through what I presume were several realignments or internal configurations.
I tested a page, and ran the HP Dinostic's page. Everything checked out, and its running fine for now.
I hope this may have given you some ideas as to fixing your printer.
Feb 14, 2009 | HP PSC 2350 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
27 people viewed this question
Seeker5211
Seeker5211
