Question about Tornado CV 30 Vacuum
Tornado vacuum overheating
Vacuum cleans good but overheats and shuts off.
  • 294 Answers
Overheating can be caused by several things. First check the bag and filters, clean or replace them if needed. Also check the suction path for any clogs or obstructions. Most vacuums have a thermal cutoff designed for safety to turn off the motor in the event of getting too hot. If all of the above does not solve the issue, the next to look at would be electrical connections and checked out by a qualified technician.
Posted on Oct 22, 2014
Lg vacuum cleaner overheats and shuts off.what is a problem?
How to Fix Vacuum Cleaner
With the link that i have attached i sure do hope that you will solve your overheating problems and others just in case. There are diagrammatic instructions also. Hope the information is useful and helpful.
Sep 17, 2016 | LG Vacuums
My dyson dc07 wont turn on
Hi Mike, it's Jack at Dyson.
If your DC07 shut off while you were using it, and now will not turn on again, it may have overheated. Most Dyson vacuums are equipped with a thermostat which will shut them off for protection if they begin to overheat. This can often be due to a blockage, or because the filter needs a wash.
However, if it's been over 24 hours and the vacuum still won't run, it's likely there's a fault elsewhere. We'd be happy to help you check for this - you'd just need to give our experts a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Dec 27, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Seems to overheat and shut down
clean the hose very well that is sure to fix you problem I repair vacuums for a living this is very common do not use it again until you clean the hose really well stick a pole to a broom all the way through the hose and rinse the filters in hot water and let them air dry and it will run like normal when you push the broom stick through the hose it will free it of any debris if this does not work it is trash
Mar 19, 2014 | Vacuums
Vacuum cleaner stops
The motor has a thermal reset built in. If the filters need replaced the motor can overheat. Filters should be replaced frequently to insure proper cleaning suction and motor life
Jan 04, 2014 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Overheating dyson dc14
Probably has a blockage (like that's a surprise). Seriously if you have pets, these vacuums get 'hair-balls' that clog passages, overheat and will shut themselves off to protect the motor. You pretty much have to disassemble to vacuum and clean it thoroughly. You'll usually find the problem while taking it apart. I take mine apart (not the same model) about once a month. I have dogs ...
Jun 15, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
After using the unit for a few minutes it cuts off.
The electric motor inside your Dyson has a built in over-current trip to protect itself (and you if it seriously overheated and caught fire). This normally automatically resets itself, however if the motor has just about had it, next time it is switched on it just trips again.
The primary cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Dont be fooled by Dyson's "lifetime filters". They need to be regularly cleaned and replaced when necessary.
Replacement motors are available on eBay for about £25, however replacing one requires good DIY skills and tools.
Have a look at www.dysonmedic.com and see if you feel you can tackle it yourself. If not, take it to a repair shop or call the Dyson helpline.
Apr 17, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dysons animal overheats and turns off What do we
Replacement motors are available on eBay2_bing.gif for about £25, however replacing one requires good DIY skills and tools.
Mar 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vaccume overheats and shuts down
Check your filters. Not changing or cleaning your filters suffocates your motor, so that could be the problem.
I suggest checking your local yellow pages for a local vacuum shop and have them fully inspect your vacuum for any clogs.
Mar 22, 2010 | Hoover U5753-900 WindTunnel Bagless...
Shark euro-pro x upright vacuum that shuts down every 15 minutes
These are prone to overheating. The manufacturer put a foam 'filter' wrap around the electric motor. This filter wrap insulates the motor, trapping heat inside, which causes overheating. The motor is very similar in form and function to the one in the Hoover Windtunnel, but the Windtunnel has no filter wrap. It doesn't overheat, and functions fine without it. There is a filter on the intake anyway. It's a redundant filter, and I have removed mine. It works fine now.
If you take the filter out yourself, you will need a special screwdriver for one of the motor cover screws. I guess they don't want the consumers opening it up.
I suggest taking it to a vacuum repair shop and explaining to them the problem, and asking them to remove the filter wrap from the motor.
Jan 11, 2010 | Euro-Pro UV209 Upright Vacuum
Motor overheats and shuts off
The priamry cause of motors overheating is that the filters are not cleaned or replaced frequently enough. Once a motor starts to overheat, it has already been damaged and even after the filters have been cleaned, may well still overheat and cut-out. The motor has a built in over-current trip to protect itself (and you if it seriously overheated). This normally automatically resets itself, however if the motor has just about had it, the moemnt it is switched on, it just trips again.
Replacement motors are avaible on eBay for about £25, however repalcing one requires good DIY skills and tools.
Oct 17, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Tornado CV 30 Vacuum Logo
126 people viewed this question
Top Tornado Vacuums Experts
JoeVacs
Are you a Tornado Vacuum Expert? Answer questions, earn points and help others
