Question about Honeywell Truezone HZ432 Zone Control Panel
On my HZ432 zones 3&4 lights are blinking indicating a short. How do I correct? Are there breakers within the system?
Product HZ432 Honeywell TrueZONE control panel. Instruction guide states flashing lights indicate a short, indicating a zone breaker has tripped. How do I find those "zone breakers" to reset?
SOURCE: Snowflake blinking in one zone
i saw that my snowflake was blinking while the unit was in the 5 minute lock out state (after power up), but went to steady after that.
Posted on Jun 15, 2008
  • 833 Answers
SOURCE: How can I repair a
Replace it...you'll need to do that in a year if you get it to run at all by monkeying with it.
Posted on Nov 23, 2008
pierre1811
  • 144 Answers
SOURCE: Resettable fuse/breaker for TZ-4
The power to your zone panel is from the furnace or air handler. There is a 3 or 5 amp fuse on the circuit board inside the furnace or air handler. I hope this helps. Please don't forget to give me a Fixya rating.
Posted on Mar 14, 2009
  • 659 Answers
SOURCE: one of my 3 zone valves on my hot water base board heatig system
You need to check for power to the zone. If you have power then the valve is bad and needs replacement.
Posted on Mar 22, 2009
  • 659 Answers
SOURCE: zone valve does not open
You need to check and see if the zone is getting the call to open. If it is, then the motor is bad and needs to be replaced.
Posted on Mar 23, 2009
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
Can i only have one zone open at a time with the HZ432 TueZone panel on a dual fuel set up with single hp and a single stage gas furnace?
The number of zones usable at one time depends on the initial fan cfm , which may be adjustable if it is a multiple speed blower motor If so put motor on highest speed and recheck ..
If it is variable speed, it is controlled by electronics in motor and circuit board and motor . Also you must check coils and blower wheels for dirt . Hint if blower wheel is dusty evaporator coil must be exposed and cleaned. Duct work also needs to be balanced for correct airflow
Nov 29, 2014 | Honeywell Hz432k Multistage Truezone...
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
How do i reset a zone circuit breaker in an hz432 control panel
remove cover and look for a micro switch labeled purge press and hold for three seconds all zones will reset all dampers will open equipment fan will run for up to five minutes and a yellow lite will flash
May 31, 2014 | Honeywell Truezone HZ432 Zone Control...
Blinking red light
Copy following link to identify type of gas control valve, and error codes.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
With honeywell atmospheric gas control, steady blinking light indicates correct operation.
Read product manual, and perform regular maintenance as outlined in product manual.
Mar 25, 2013 | Water Heaters
I have a honeywell emm-3 electronic mini zone for a few days the LED light was blinking orange indicating sensor failure. However, there is no sensor but it sounds like the damper motor was struggling....
check the board for 24 v.a.c. or whatever voltage is used to supply this board,normally its 24v.a.c. from a small transformer,if this transformer burns open the thermostat will not operate
Apr 18, 2010 | Heating & Cooling
My Honeywell EMM-3 zone controller system LED is flashing orange, indicating DAT fault. How do I verify the DAT is faulty?
Hi
Thanks for using FixYa. Perofrm this test--
Connect DATS Sensor to EMM-3 (optional).
a. Reconnect power to EMM-3.
b. If system is in Purge mode, press PURGE OVERRIDE on EMM3.
c. Verify SYSTEM LED is no longer flashing. This confirms proper DATS operation. (Flashing occurs in Idle and Fan modes only.)
Also see page# 9 & 10 from this link--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 28, 2009 | Heating & Cooling
Short burn cycles
if thats a new themostst it sounds like you didnt set the cycle dip switches correctly,the type of heat you have is unknown to the thermostat so you have to tell it or it may short cycle or overheat
May 02, 2009 | Honeywell Heating & Cooling
Mar 13, 2009 | Honeywell Heating & Cooling
Honeywell Truezone HZ432 Zone Control Panel Logo
88 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
