Part of my LCD screen is missing.
The moment I switch on my notebook computer, a white strip, which is about an inch, or an inch and a half wide appears from top to bottom of the screen on the left hand side of it. The area covered by the strip is always totally devoid of images.The strip remains as long as the computer remains on.
  • 50 Answers
This sounds like you have a damaged LCD screen or dead pixels. I don't know anyway to solve this besides changing the screen.
The only other thing would be a motherboard problem meaning u have to change that but most likely its the screen.
Posted on Jan 23, 2009
Strip of screen is white
How big is the strip? If it is 2 or 4 inches wide, then your panel is bad. If it is half of the screen then you could just have a loose connector or a bad t con board.
Apr 10, 2012 | Sony BRAVIA KDL-40S2010 40 in. LCD...
White stripe on screen cannot get it off. Approximately one inch wide from top to bottom of screen. Curser will go under it and it will not phase the strip.
This is a problem with the LCD panel itself. The controller for the panel has failed. You will need to contact Asus for a replacement part if it is still under warranty.
Jul 06, 2011 | ASUS K52JT-XT1 Laptop Computer - Intel...
5 inch wide bands of colors on my computer screen... flashing...
you have a broken lcd screen and will need to replace it, if this appears from the moment you turn it on
Mar 15, 2011 | HP Compaq nc6320 Notebook
I have a white strip approx one inch wide down the left hand side of the screen on my Toshiba P100 laptop. What causes this, and is it fixable? Thanks.
Usually this is a sign of a failing LCD or a bad ribbon cable. Try to reseat the cable in the back of the screen. If that doesn't cure it, then I'd recommend looking for a new screen.
Jul 18, 2009 | Toshiba Computers & Internet
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Jun 16, 2009 | Philips 200P4 (Silver/White) 20.1 in. Flat...
LCD Screen turned opaque at two places, I see two white opaque lines 3 inches wide one on left side of screen and other in the middle
Yes you are correct. I would say 95% of the time, you will need a LCD screen replacement. Also be sure to disconnect and reconnect the lcd cables, at the motherboard and behind the lcd itself, just to make sure the cables aren't making bad connection.
I have provided you a link to MANY lcd screen for your laptop on EBAY.
http://computers.search.ebay.com/Satellite-P100_Screens-LCD-Panels_W0QQcatrefZC6QQcoactionZcompareQQcoentrypageZsearchQQcopagenumZ1QQdfspZ32QQfromZR2QQfsooZ2QQfsopZ32QQftrtZ1QQftrvZ1QQsabfmtsZ1QQsacatZ31569QQsargnZQ2d1QQsaslcZ2QQsbrftogZ1QQsofocusZbs
Hope this helps you. Please rate my solution.
May 16, 2009 | Toshiba Satellite P100 Notebook
VERTICAL WHITE BAR ACROSS THE LCD SCREEN
Almost certainly the LCD panel has failed, and would be replaced by Dell if it is still under warranty. You can try to replace the VGA or DVI cable that connects the LCD to the PC. If the problem persists it is the LCD.
Mar 18, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
Missing key strokes
check the connection under the keyboard. you might have to remove the panel near the screen just above the keyboard ito get to the screws. the plug is usually what looks to be a plastic band with lines on it that slides into a thin slot. i had the same problem with my laptop screen. there were white, green, blue and red strips of pixels every inch and a half.
Oct 21, 2008 | Toshiba Satellite M55-S135 Notebook
Screen Problem
Unfortunately the fix is a new lcd. The tab welds at the top of the lcd are not allowing that portion to work correctly. As these tabs are fused to the lcd you will need to replace the lcd. My Toshiba M105 is almost the same.(I Have 4" Gone) on the right side. so to use it I clicked and dragged my system tray from the bottom to the side. And shrunk my web pages to utilize tthe good portion.
I suppose I should replace it but being only 18months old the LCD's run about 160.00 USD.(sometimes I just hook up an external monitor.
Apr 16, 2008 | Toshiba Satellite P105-S6207 Laptop
Computers & Internet Logo
251 people viewed this question
David Payne
David Payne
