Question about Lexmark X2500 All-In-One Printer
Reset Lexmark 36 Black cartridge?
Is it possible to reset a Lexmark 36 Black cartridge? I've got a X4650 Wireless all in one printer. I print a lot and was wondering how to reset the cartridge so that I could refill it?
  • 2 more comments
  • starzfan31 Mar 09, 2009
    This did nothing for my printer...   refilled.. taped off both sides.. it says there is no cartridge in the printer.     take off the tape and put it back in,, it stills shows empty.   grrrrrr
  • sallys1906 Mar 17, 2009
    Have refilled and reset cartridge, now printer only prints black using colour cartridge, which will also run out soon. Does not see the cartridge.
  • Anonymous May 12, 2009
    No, that does NOT work. You may be printing, but you're printing process black using the color cartridge. (Ie. it's mixing cyan, magenta, and yellow to make black).
  • Victor
    Victor Feb 27, 2014
    #36 of the Lexmark, works great with the two (2) outside bottom connector dots covered, now it prints and says the cartridge is full.
BINGO just refill my 36 and printing :) just place tape (2) on the bottom the outside points
ONLY THE ONE OUTSIDE BOTH SIDES :) :) :)
HP his something like this too. 2nd try BINGO IT WORK drill right hole place tape back over refill hole LOL
Posted on Feb 09, 2009
  • Domenico Lustri Oct 18, 2012
    Hi, I've read this old post with interest and tested the proposed solution on my 36XLA cartridge. I've also tested a similar method proposed in a video (search for "how to make # 36 ink cartridge works after refill- lexmark 5650"). Well, it's true that in both ways I get a question mark on my black cartridge in my printer settings (I have a x4650) but I actually get the same thing if I completely remove the cartridge. What is happening to me is that I stop getting the low ink level messages but simply because the printer thinks that there is no more black cartridge installed and simply uses the color one. If I remove the color cartridge from the printer and simply leave the taped black one, my printer simply tells me that there are no cartridges installed at all and won't simply print anything. Not sure if anybody saying that the taping workaround works has tried to leave only the black taped cartridge in the printer. For me this solution is simply not working. Thanks, Domenico.
    Problem Solver:
I hope that I may help someone that's confused about were to tape. Hold the number 36 cartridge with the gold contacts facing you. The two gold pads that you need to tape are located on the bottom row on the outside. remember don't tape the ones in the middle, just the two outside ones. One on the left and one on the right. When you are finished you will have tape, two gold square pads and tape. I used blue painters masking tape and its working well....
Posted on May 20, 2010
  • Taternater Jan 19, 2011
    Just proves there is nothing that a little duct tape can't fix. I used white duct tape.
That worked like an absolute charm. I was looking on Ebay for reset chips and was willing to pay but this free solution is perfect. BTW, I have a Lexmark 5650 and scotch tape works just fine. Does anyone know which contacts you would cover for the 37 cartridge?
Posted on Jul 09, 2010
  • 4 Answers
It works, just used my #14 lexmark after refill. I put tape on the 4 bottom points of each sides. You will see 1 alone at the bottom and 3 in a group in the middle, tape the 4 and do the same on the other side. Put it back in the printer and it works... It will dispay a '?' on the ink cartridge level and status when you print.
Posted on Aug 14, 2009
??? Which 4 points are you guys talking about? I wish there was a picture so i could see which points that i need to tape.
Posted on Apr 24, 2010
  • Victor
    Victor Feb 27, 2014
    #36 of the Lexmark, works great with the two outside bottom connector dots covered, now it prints and says the cartridge is full.
I drilled my hole in the top of the 36 over the "e" in Lexmark BEFORE I installed it in the printer. I will add a little ink every once in a while before it gets down too far to trip to the 'needs a new cartridge soon' level. I'll let you know if it works. For the 37, without taking off the top and seeing where the color sections are, I won't know until I can take apart a used 37. Then I will try the same time. This way, I don't have to remove the cartridge....we'll see how it works!
Posted on Oct 10, 2009
I replaced a lexmark x4650 black ink cartridge #36 with another lexmark #36. when I try to print I get an error message stating that the left cartridge(the one I replaced is incorrect). Any suggestions?
You might have put it in incorrectly. Sometimes it could be as simple as taking the cartridge out and putting it back head but make sure it is snapped in correctly. Also, you could try unplugging the machine, taking the cartridge out and then replacing it once the machine is on. That could work as well. If it doesn't let me know.
Jul 26, 2011 | Lexmark X4650 InkJet Printer
I have a Lexmark X4650 wireless printer that for 1 year has been working perfectly after each cartridge (blank and white Lexmark 36 or Colour Lexmark 37) I come to change the colour cartridge this time...
If you're using genuine Lexmark cartridges and you've already tried rebooting your printer and reseating the color cartridge in the ink cartridge carrier, then it could be a faulty color cartridge. Your cartridge may need to be replaced from the retail store where you bought it from. If it's beyond the return period, in that case, you'll need to contact Lexmark technical support for additional assistance.
May 15, 2011 | Lexmark X4650 All-In-One InkJet Printer
How do I reset a refilled printer cartridge for a Lexmark X4650?
They are not resettable. This is one of the downsides to using refilled cartridges for this style cartridge. You should be able to tell the printer to ignore the ink levels and just print until it runs out of ink.
Jun 09, 2010 | Lexmark X4690 Wireless InkJet Printer
Refill lexmark 37xl ink
I own a Cartridge World ink refilling store and we do not refill the Lexmark 36 and 37. The reason is that your printer turns off the electronics on the cartridge when the ink gets low, so you can't reuse the cartridge. Your printer will only function with an electronically functioning cartridge. We NEVER recommend Lexmark printers. They are poorly made, don't accept refills a lot of the time, and across manufacturer their ink costs the most and is designed to clog the cartridge if you don't use it fast enough. We recommend HP printers that take integrated print head cartridges and Canon printers that take tank style cartridges.
Mar 01, 2010 | Lexmark X4650 InkJet Printer
I have a Lexmark X4650 I refilled the cartridge and now I cannot get the printer to recognize the cartridge it prints black only and tells me Color is low . any suggestions on how to bypass this prob get...
I own a Cartridge World ink refilling store and I can't refill the Lexmark 36 and 37 cartridges. Your printer deactivates the electronics on this cartridge when the ink levels get low. Your printer needs a black and a color cartridge with functioning electronics to print. I NEVER recommend Lexmark printers. They are poorly made, don't accept refills easily, and have the most expensive ink across manufacturers and it is designed to clog your cartridge unless you use it quickly. If you keep this machine you are stuck buying Lexmark brand ink (the return program cartridges are a little cheaper though).
Dec 24, 2009 | Lexmark X4650 InkJet Printer
Won't Print x4650
Hi
Here are a few possibilities...
1. Try cleaning the contacts on the inkjet cartridge and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer reinstall driver.
4. Try installing old cartridge to see if printer rejects that?
5. You may have a faulty inkjet cartridge (return it to store if so)
You may find more help here...
How to Clean, Fix, Repair, Unclog, Dry, Clogged Print Heads on CANON, EPSON, HP, Lexmark, Dell, Olivetti etc…
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 11, 2009 | Lexmark X4650 InkJet Printer
Lexmark x4650 says "print cartridge missing" but just replaced.
CLick on Start, printers and faxes, right click on your printer icon, click on properties.
There should be a tick box to allow you to reset the cartridges to new....
Jul 01, 2009 | Lexmark X4650 InkJet Printer
Comparable hp ink cartridge for lexmark x4650 printer
Yeah, here's my solution: Send the Lexmark printer back and bought an HP all in one.
Thanks
Apr 01, 2009 | Lexmark X4650 InkJet Printer
I managed to get it working, just damage the connection point (where the chip is). I used a knife to break part of the connection and now I can fill the cartridges myself for a fraction of the price :)
Mar 05, 2009 | Lexmark X4650 InkJet Printer
Lexmark X2500 All-In-One Printer Logo
13,125 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
