Question about Emerson CKD9901 Clock Radio
Blinking wont stop what to do?
Has new battery did not help
Light wont stop flashing
Light flasher will not stop flashing.
Jan 13, 2014 | RCA Televison & Video
Possible electrical problems
check battery terminals and posts are shiny clean and tight. Check earth wire from battery is tight on the engine or block. Check for loose fusible link.. The problem Is the main power lead from the battery has an intermittent connection. If the battery is not off the shelf new but a friends new battery then have it load tested for a faulty bridge or cell
Dec 14, 2013 | 1999 Oldsmobile Silhouette
Sager 8880 wont run on ac adapter or charge battery, has new battery and ac adapter it does work with battery but now the battery is almost completely discharged and now i get battery light blinking and...
Hi Kenneth,
Have you checked to see if the charge connector on the laptop is loose when you plug the charger into it? You can see if it is by plugging it in and wiggle it around a bit. The charge light on the laptop might stop blinking if its moved and contact is made.
Thanks,
Gary
Aug 01, 2013 | Gateway MX6956 Notebook
The green power button and orange battery light keep blinking. is it time for a new battery?
maybe. isolate it first. try using new battery. if the blinking lights stops, then it needs new battery. if the blinking do not stop check the power adapter maybe that is the defective. it did not give enough power to charge the battery.
Jun 03, 2010 | Acer Aspire 7520-5185 Laptop
I HAVE A 36 VOLT DEWALT RECIP SAW, THE BATTERIES ARE NEW AND SO IS THE CHARGER. BUT THE CHARGER KEEPS BLINKING AS THOUGH THE BATTERIES ARE RUINED. CAN I RESET THE BATTERIES TO TEST
Charger blinks while charging, stops when batteries are fully charged.
New batteries may not be charged from factory. Let them charge overnite and see if it stops blinking.
Feb 05, 2010 | Dewalt Drills
Wont turn on, new batteries, green light just blinks.
Make sure you are using the correct batteries, and that they are installed correctly. Some cameras require more powerful kinds of batteries and will not work with the cheaper kinds.
A blinking light can mean something is wrong with the power, not enough or something else.
If you have a power adapter or can get one, you may try that, to see if the camera will work without batteries. If it does, then some problem exists in the battery circuit.
Oct 20, 2009 | Samsung S860 Digital Camera
Wont start, security light keeps blinking
Turn the ignition switch to the on position and let the light blink. It should stop in about 10-20 minutes. then you can start the engine. if the light does not stop blinking likely the key switch is bad or, (less likely the module). Make sure your battery is in good condition when doing this or it wii kill the battery before the coding is complete (use a jumper to a good battery if necessary but don't turn the other vehicle on)
Oct 13, 2009 | 2003 Pontiac Grand Am
Guitar hero 3 corldless guitar wont work
factory defect most likely so send it in or return it for a new one
Sep 14, 2008 | RedOctane Guitar Hero 3 - Legends of Rock
Hp photosmart r725 won't charge
I had the same problem. Did you ever figure out how to fix it? I called HP and they said I needed to buy a new one.
May 01, 2008 | HP Photosmart R725 Digital Camera
V3i Problems
you need to have the flex cable replaced
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Emerson CKD9901 Clock Radio Logo
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
