Question about LG BH7420P Cinema System BRay Players
Lg bh7420p no sound when watching tv
Radio ok
3 Suggested Answers
  • 4102 Answers
SOURCE: 42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Posted on Dec 14, 2007
tvservice306
  • 458 Answers
SOURCE: lcd LG television...sound suddenly stopped. no
replaced main board
Posted on Aug 18, 2009
I bought a LG 42LB1D LCD tv about 5 years ago.I hardly watch this tv. When i watching dvd few days ago all of a sudden i see only BLACK screen sound is OK and remote control is not consistent sometim
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Dec 11, 2014 | LG 42LB1D 42 in. HD-Ready LCD TV
No picture
This is a common problem with this TV caused by a failed buffer board, usually the top one.
Here's two links that explain it, tell you how to test it and provide solutions:
http://www.coppelltvrepair.com/p/1173/lg-50pa5500-ua-top-buffer-board-replacement-for-tv-starting-with-no-image-problem-50-credit-for-old-dud
https://www.youtube.com/watch?v=z3dxCJ3CaTs
Hope this helps!
Apr 18, 2014 | LG 50PA5500
My lg bh7420p surround sound system is distorting through the front speaker on dvd playback
Check if the speaker cone paper is teared off or got some hole on it. Or may be the outer ring of cone/cap is loose ,
Apr 13, 2013 | Entertainment Lg Bh7420P 3D Blu Ray 5.1...
Lg bp220
You maybe able to get a region free code from these WEB sites for your player.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Jan 02, 2013 | LG BH7420P Cinema System BRay Players
How to set LG BH7420P to multi region
So did any of these hacks actually work?, as there are a few, and I was thinking of buying the system, thanks.
Dec 27, 2012 | Televison & Video
How do i get the regular cinemate system to run through my tv so i can watch cable tv while using the sound system. My tv is the LG 55LH55 the cable comes from the wall outlet directly to the tv. no dish...
Hello,at this point you have two options, You'll either need the home re-wired so the receiver is in the same room, or you can try purchasing an RF modulator. This is basically a cable converter you can find these at radio shack. Hope this helps!!!
Daniel Busa
DISH Network Customer Service
Jan 15, 2011 | Bose Cinemate Digital Home Theater System...
I have an LG all in one home theatre system, LCD TV and Direct TV satellite box. It is all hooked up and working fine except I only hear the sound through the speakers when playing a dvd or radio. The...
OK. For all you regular Joe's like me here's the fix--plain and simple! I have Dish Networks HD receiver, an LG Home Theater System (LHB953) and an LG HD Television - although I suspect this applies for most LG TV-to-LG Audio Systems used in combination with a HD TV). My problem lied within the LG to LG setting known as SIMPLINK which tries to "auto-configure" everything between LG to LG devices.
Do this to make your HD TV (using Dish/DirecTV) play it's HD video display from the satellite provider but play the audio over the LG surround sound speakers:
1. Plug a HDMI cable from your satelite receiver's set-top-box to your HD TV. This will carry your HD "video" ONLY. Click "Input" on the TV remote until the HD video signal shows your desired TV channel from your satellite provider.
2. Plug an HD Optical cable (the one with the red laser) from your LG HTS (Home Theater System) to your satellite box. This will carry your HD "audio" ONLY.
3. This is the magic everyone seems to be overlooking. On the LG TV remote, go into the menu options and disable SIMPLINK by setting SIMPLINK=OFF. This feature allows the video and audio signals to be split over 2 different ports: HD video goes over the HDMI cable and the audio to go over the HD Optical cable.
Hope this helps!
Scott C.
Feb 01, 2010 | LG LHB953 Theater System
LG BH7420P Cinema System BRay Players Logo
Computer Repairing
Computer Repairing
