Question about Walgreens Personal Steam Inhaler Kit
Directions for using the personal steam inhaler
Can I use a pinch of epson salt in the Vicks vaporizer
No it will mess up the vapor you inhale it will hurt your eyes and brain
Mar 09, 2017 | Vicks Humidifiers
Need online instruction manual for hankscraft humidifier model 240
I found this. There are no manuals available on line.
Here we have a used working HANKSCRAFT / GERBER COOL VAPOR HUMIDIFIER Model 240 WITH INSTRUCTION MANUAL and STEAMED CLEANED. This humidifier, by Gerber, has a 1 3/5 Gallon Capacity, and produces cool vapor for up to 18 - 20 hours in low, medium or high settings. The humidifier works great , does not have the directional nozzle included but does come with a copy of the instructions.
http://www.ebay.ca/itm/331790662762
Dec 03, 2016 | Humidifiers
I was given a Vicks Vaporiser model V188, no box, no instructions etc. I just assumed you filled it with hot water & put eucalyptus oil in the water & plug out in the wall & that's how it worked. Now that...
vaporisers are a great way to make your home a healthier air environment , first id like to caution you on what you add to your water feed , b sure it doenst contain any chemicals that might degrade in heating to be toxic to humans , example( air fresher's) these contain sometimes propane as a propellant and that shouldn't be added to live steam , read the labels on what u add to water ??? next im not sure why you couldn't breath in the steam , I do suggest you use a large bath towel and drape it over your head and hang it down over vaporizer to catch steam , this is safer than sticking your face over one directly also these machines do require weekly cleaning and do manage to get bound up with minerals that are in tap water left behind inside the unit , its best to keep a indoor air humidity of 70% rh in winter and summer for proper health , gauges for this measurement are cheap and easy to obtain
Mar 02, 2017 | Humidifiers
We have a water softener and I think the water has too much salt and therefore, our Vicks vaporizer has too much steam. Any suggestion?
If your softener is working properly, you should never get any salt in your water. The salt is used only to reactivate the ionic media in your softener cartridge, and during the backflush cycle, all that salt is removed, down to PPM (Parts Per Million) levels.
In any case, even if you used salt water in your vaporizer, it would not increase the amount of steam that it produces. Salt water has a higher boiling point than fresh water. You would also notice salt buildup inside the tank as the water level goes down.
The Vicks Vaporizer works by using only heat to produce steam- the hotter it gets, the more steam it makes. The only practical way to get too much steam outside of a malfunction that causes your heating element to get abnormally hot would be if you live at a very high altitude where water boils at a lower temperature.
High humidity in your home will make it appear as if your vaporizer is making too much steam since the surrounding air will be less capable of absorbing it.
A slightly "off topic" note- if you chose the Vicks Vaporizer/humidifier and have children, you have made a wise decision. Because it produces water vapor by heating instead of ultrasonics, contaminants and minerals (such as salt, iron, calcium, etc.) remain in the tank and will not enter the vapor stream.
Mar 25, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
My vapourizer is not steaming, why?
The most likly cause is a build up of mineral and calcium around the heating element. If you can remove cover around element then you can clean by gentle brushing. Some units require the use of a torx driver to disassemble. Otherwise clean around cover and steam outlet and run about 1/8 teaspoon of salt with full container of water. If you can get it started to steam then do this several times then rinse out and refill with about 1/2 cup of pure vinegar and water. Hope this helps you. Thanks.
Mar 07, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
I need to know how to use the warm steam vaporizer i lost the instruccions..
you add vicks petroleum paste/jelly at the top where the air vent is. Add 1-2 tablespoons of salt with tap water in the tank, plug in the unit and warm steam will produce.
Feb 16, 2011 | Vicks Warm Steam Vaporizer 1.5 Gallon...
Why is it that the steam doesn't seem to be working very well.It is a Vicks Humidifier.
use vinegar in water when steam drops then clean out water container. and use a small pinch of salt to let the two prongs in the plastic tube make better contact with each other it will steam very well.
Nov 09, 2009 | Vicks V150SG 1 Gallon Humidifier
Thick Cloud of Steam
I would say that the beauty of steam is that it has to get through the 100 degree temperature to leave the aqueous state - i.e. to move from a liquid to a gas.
The benefit of that is that any organizums in the water should be killed as a result of that process. Its possible that it smelt musty or old stagnant water smells but to be honest there is little change of harm to the little ones.
Best wishes
Aug 08, 2008 | Vicks Ultrasonic V5100 Humidifier
Walgreens Personal Steam Inhaler Kit Logo
47 people viewed this question
Top Walgreens Humidifiers Experts
Dennis
Rich Brown
Tom Chichester
Are you a Walgreens Humidifier Expert? Answer questions, earn points and help others
