KENMORE MODEL 93901 SMOKING AROUND WASHER DRUM
HEARD SQUEELING DURING WASH AND AT TIMES DURING SPIN, THINKING MAYBE BELT MAY HAVE BEEN SLIPPING? DID ONE COMPLETE WASH AND DRY WITHOUT HEARING NOISE AND STARTED 2ND WASH AND SHUT OFF MACHINE AT END OF WASH SO TO SOAK CLOTHES AND LEFT THE LAUNDRY AREA, WENT BACK AFTER AWHILE AND COULD SMELL SOMETHING BURNING. SAW SMOKE RISING FROM WASHER BARREL AND FROM BEHIND THE UNIT
catriver
  • 878 Answers
SOURCE: "howling" noise during spin cycle (still there after changing burned off belt)
Travioso, there was two service flashes out on this model concerning the seal and bearing which means they had an issue with this washer. The howling noise you are hearing is the bearing and will need the new designed triple seal and bearing kit. This should be covered under your warranty, I believe it is 5 years. The numbers for the service flashes are TDL-0048A-B. Call Maytag and inquire about these service flashes, these should be covered. Catriver.
Posted on Jul 25, 2006
jsrock516
  • 5911 Answers
SOURCE: kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Posted on Aug 02, 2007
  • 7 Answers
SOURCE: loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Posted on Apr 08, 2008
jsrock516
  • 5911 Answers
SOURCE: Water Building up Inside Front Load Washer when not in use
Okay, it is normal to hear water sloshing around inside the wash tub when the washer is not in use. A small amount of residual water remains in the wash tub under the wash basket (stainless steel tub), and resides in the drain line and drain pump. That's why it is important to keep the door slightly open when not in use to allow the drum to air out. The water will not evaporate, but it will help reduce the build up of odors, mold and mildew.
Now...if your washer is slowly accumulating water in the wash basket area over time, your water inlet valve is probably starting to fail. The leak can be very subtle and you may not notice it. The water only comes from one source - the fill valve via the dispenser. If you wish to replace it, the part is available at searspartsdirect.com. Just type in your model number and the part you need can be found under the "Dispenser" heading as item number 1. The replacement is very simple if you follow these steps:
1. UNPLUG the washer and turn off water supply.
2. Remove both fill hoses.
3. Remove the top panel of the washer by removing the screws that hold the panel in place in the rear of the washer.
4. Slide the top panel back, then it lifts off.
5. The water inlet valve is located in the left rear of the washer as facing from the front.
6. Remove the rubber hose leading from the valve and the electrical connections.
7. Remove the mounting screws holding the inlet valve in place.
8. Re-install new valve using these steps inthe reverse order given.
I hope you find this information helpful. If you have further questions, please post back and let me know.
Posted on Jun 06, 2008
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Posted on Oct 29, 2008
THE MACHINE RUNS VERY WELL QUIET UNTIL THE FINAL SPIN CYCLE THEN FROM THE BACK OF THE MACHINE THERE IS A SQUEAL THAT GETS LOADER AS THE SPEED PICKS UP
This may well be the drum drive belt in the back of the washing machine. This belt transfers drive from the motor to the drum for both wash cycles and spinning. If the belt is slipping slightly on the pulley then a squeal may well be heard on the spin cycle and will change in pitch as the speed of the drum increases. At lower speeds (wash cycles) the belt probably won't slip. I don't personally know of this model but there is usually a tension adjustment nut/bolt near the motor to tighten the belt and stop it slipping.
Dec 26, 2013 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I washed a load of clothes and the washer worked perfectly until the last 3 minutes where the washer does the final spin and all of sudden smoke pours out of the back of the washer and when I opened the...
well is it a smell of burning rubber? maybe the belt that turns the drum has got jammed. over time these belts get loose and when a full load of clothes are washed the belt slips creating heat hence the smoke..hope this helps..
Dec 04, 2013 | GE WSXH208A Front Load Washer
The washer fills wiht water but wont spin. it looks liek the belt slipped off because it was shaking too much.
Did you remove the shipping screws from the rear? They are installed to stop the unit being knocked around during transport, but if let in they hold the drum and prevent it from moving.
Jun 09, 2011 | Kenmore 24182 Front Load Washer
Squealing noise during wash cycle
yes thats a belt slipping may have something in the pump maybe a coin or a small item like that.
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Washer model LA182 loud while washing.
there should be a belt tensioner on thebelt path check to be sure the belt is not slipping
Aug 14, 2009 | Kenmore 44102 Front Load Washer
Maytag washer will not spin, clutch slipping
Sound like it's time to go shopping, sorry
Jun 20, 2009 | Washing Machines
Squeeling sound on spin cycle
This sounds like the same problem I had with my 887-327. It seems that coins can fall into the water pump from the bottom of the drum. I had to pull the water pump off the direct drive and turn the blades until the dimes came out. After I reinstalled the pump everything was quite again.
Nov 24, 2008 | Kenmore 88732 Top Load Stacked Washer /...
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
