Question about Boating
Motor does not seem to have any spark i have replaced the plugs
    Sergeant:
  • 248 Answers
The spark plug gets its power through the ignition coil.
Posted on Jan 13, 2013
  • helen cullen Jan 15, 2013
    THERE IS NO IGNITION IT IS A PULL START DOES IT STILL HAVE A COIL?
  • djgough Jan 15, 2013
    My bad - These kinds of motors get their power from a magneto. This may be of some helphttp://www.ehow.com/how_7948575_test-mag...
there is always a cover to the motor that keeps you from getting burned. Remove the cover, find the spark plug wire (thick black wire with a "boot" on one end). After tracing that wire to the "boot", simply remove the boot exposing the spark plug. Using a "spark plug" socket (usually 5/8 deep socket with hex head and rubber stopper inside), fit over plug and turn counter clockwise. After removing spark plug, check your manual for gap rating of new spark plug. When completed the gap put new spark plug into hole, finger tighten plug, then snug it down with the "spark plug socket". Once it gets a little tight, tighten 1/4 to 1/3 turn (this "seals" the spark plug ring)...DO NOT OVER TIGHTEN, this could cause the ceramic to crack causing an arc which will make motor seem to run rough.
Apr 20, 2014 | Toro Garden
After replacing spark plugs motor idles or seems out of timing
check to see if you put spark plug wires on correct plugs . If fireing order is correct check for a cracked or miss gapped spark plug
Jul 30, 2013 | 2003 Ford Focus
Motor quits when pull trigger
It's the spark plug more than likely. If engine turns but won't stay running its more than likely spark plug. If that doesn't fix its the gas. Empty gas out get some fresh gas.
Jul 13, 2013 | Campbell Hausfeld PW2102 Gas Pressure...
I cant pull the cord, everything seems to be frozen
It is possible the motor is seized or the pump component has jammed. The Honda Motor usually has an oil minder(wont start if low oil). So that being the case you may have a problem with the pump. If you are handy and have internet it is possible to download a parts/repair manual for the type of pump involved. Otherwise take it to a repair shop. Sometimes these pressure washers are more costly to fix as compared to a new one..
Nov 06, 2011 | Honda Maxus Prosumer MX5223 Pressure...
Toyota 1993 went in deep water motor seized no water got in the motor seemes to be locked
If motor seized it got into the air intake. You should remove the spark plugs to get the water out. Turn engine over with the plug wires away from plug holes. Replace with dry plugs and try to start car and hope none of the connecting rods got bent.
Sep 11, 2011 | 1994 Toyota Camry
Stored over winter. New battery fresh fuel wont start. Doesnt seem 2 be a spark peugeot speedfight 2 03. Any advice thanks clive
When gas sits it will, turn to a gel to make it simple. this can block the very small holes in the carb. There is a very simple way to check if the motor will run without taken everything apart. remove the air filter, get yourself a can of carb spray, brake cleaner, or wd-40. Open the throttle the whole way and spary which ever one you choose to use into the air intake let the throttle go and try to start the motor. if it starts then you know you have a fuel problem. If not then the next thing to check is the spark plug, remove the spark plug from the motor, place the spark plug cap back on the spark plug put the spark plug on the motor and spin the motor with the starter and see if you get spark. If you go you know that you have a fuel issue. check this out and lme know what you find if you need help with cleaning the carb let me know.
M.Woodring
Jun 23, 2011 | Peugeot Morini Corsaro 1200 Motorcycles
Extreme loss of power while driving. Starts and idles smooth. Changed spark plugs, spark plug wires , pcv valve. Replaced radiator several months ago. Loss of power seemed to appear overnight. Any...
Is your check engine light on? If so, get it scanned. Seems like it would show up on a test. You might have a vaccum leak or faulty fuel injectors
Feb 15, 2011 | Hyundai Motor 2002 Elantra
The motor's pull start seems locked. How do I
Usually what I do first is pull the pump off the engine. After doing that use your hand to back the motor's shaft up about a quarter turn. Then without the pump on try to start the motor. If it starts put the pump back on and try to run it. Sometimes the crank and piston get set just perfectly so you cant pull it over. If that doesn't work post here again and I will help you further.
Jan 14, 2010 | Northstar Professional Series Pressure...
Troy Bilt Pony won't start
Try taking the shroud off of the motor and and cleaning the magnets on the fly wheel. Also clean the two little prongs next to the fly wheel. You can also clean the end of the spark plug cable that hooks onto the plug. I use fine sandpaper or emery cloth.
Good Luck
roundo4
Sep 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Can't get it to start. the pull cord is extremly hard to pull
take spark plug out you may have cylinder full of petrol or oil.crank motor over with rope see if its free.if liquid comes out blow out with air clean /replace plug & try again.check oil level also.
May 06, 2009 | Garden
Boating Logo
23 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
