Question about Stihl 36, 40, 44 Edger Trimmer 35mm Piston Ring 4130-034-3000
Stihl fs 36 44 Motor wont rev
Motor runs but will not rev.
  • Carmen Price Jan 14, 2013
    This trimmer idles but will not rev up at all to drive the string so I can cut edges. ThanksAndrew for suggestion will see if that helps.
    Sergeant:
  • 322 Answers
A very common problem I see with trimmers is the spark arrestor screen plugs up blocking the exhaust from exiting the engine causing the engine to not wind out like it should. If that doesn't solve the problem then check the diaphragm in the carburetor. Those units are obsolete and very difficult to find parts for so I wouldn't spend a lot of time or money on it to fix it
Posted on Jan 16, 2013
  • Carmen Price Jan 16, 2013
    Thanks for your info, I appreciate it very much
2 Suggested Answers
  • 2239 Answers
SOURCE: hi, have a stihl fs 85, runs fine for 10 minutes, then just cuts out. tried cleaning carb, muffler.
Two things spring to mind, fuel tank breather, to rule this out slacken off the filler cap when the machine starts to die, if it picks up again change the tank breather, or the ignition coil is breaking down when hot, this would require a replacment unit.
Posted on Dec 16, 2012
My stihl fs 56 rc was running great then just started bogging down and wont run right at all
Bogging issues tend to be fuel related. Check the fuel system from the filter to the carb, check the carb isn't blocked, check the exhaust is clear so that the gasses can escape.
Sep 12, 2015 | Stihl Garden
Hard to start..will not rev. up
STIHL TRIMMER-WEED EATER REPAIR: stihl carburetor ...
? 6:55
www.youtube.com/watch?v=vK6MsQalprY
Sep 16, 2011 - Uploaded by JEREMY FOUNTAIN Here is what I did for my fussy Stihl FS 250r trimmer....this after sitting all ... STIHL FS80 FS85 FC85 HS80 CARBURETOR ASSY 41371200614 ...
Aug 07, 2015 | Stihl FS 85 Weed Eater
Stihl FS85 starts fine, But not take full throttle
Pumping the primer bubble while the engine is running should cause the engine to over fuel and stall (if the tuning is correct). Sounds like its not fueling enough, pumping the primer is forcing fuel through the carb causing the engine to pick up rev's, but this is soon exhausted which is why it wont rev on the throttle.
* Check that the fuel line is not damaged and drawing in air. (if this is intact try the next step)
* Strip and clean the carb. Replace any diaphrams if needed.
* Check gaskets seal between carb, air filter and cylinder.
Just out of curiosity what standard carb settings did you use.?
May 23, 2013 | Stihl FS 85 Weed Eater
Weedeater wont rev up
check the cable at the carburator and at the trigger itself probably is disconnected or broke
Apr 22, 2012 | Stihl FS 85 Weed Eater
Where do I find a free repair manual for Stihl FS 46
If you have a nice Stihl dealer he (or she) might be nice enought to print you the specific repair information that you may need but no place that I know of offers the complete manual for free.
Sep 06, 2010 | Oregon Scientific Complete Carburetor for...
Stihl FS 85 stalls and wont start after about 20
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} 285 7772400 10058400 259 261 257 280 262 283 1 06WOHFQ%ZQT6,!3GM2\Y["P 5 1 0 286 False 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 282 134217728 1 3 -9999996.000000 -9999996.000000 8 Empty 16711680 52479 26367 13421772 16737792 13382502 16777215 Bluebird -87325200 -87325200 (`@````````` 267 263 5 No. It sounds a too simple, but try this: The next time you run it and it starts to die, loosen the gas cap. It should start to run again. This means that the gas cap is clogged up with dirt. It is not vented properly, causing the carburetor to not get gas.
Jim
Jun 10, 2009 | Garden
Stihl 36, 40, 44 Edger Trimmer 35mm Piston Ring 4130-034-3000 Logo
439 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
