Question about Sony KDF-E55A20 55 in. LCD Television
Blinking Red Power Light
After watching fireworks in HD on the 4th, the screen went blank. Sound works fine. It has been in service for The front POWER LED is blinking 6 times red, pauses and then repeats. If I press the power button I get 4 green blinks and then the same 6 red blinks. I cannot turn off the set using the remote or the front onoff button. I tried a hard reset by unplugging the set and then plugging it back in, no joy. Manual says if power LED blinks 3 times it may be the cover to the projection bulb. I have removed the bulb and it looks fine. I reinstalled bulb, no joy. I checked the voltage that powers the bulb, sperry reads zilch. I also checked for continuity between the two leads on the bulb and it reads infinity, which makes me think the bulb is bad. When I press the power button I hear a click from within, but no fan action. A couple of questions: Is the service port on the back of the unit for technicians only? Is the first step replacing the bulb or do you think it may be something else? I am willing to perform further dissassembly of the unit and check voltages, continuity and peruse for fried electronic components. Thanks.
  • 1 more comment
  • Kenneth Boutin Jul 07, 2007
    Attempting to get anything on the screen ends in failure. I don't get anything on the screen with those button combinations to see which ones and how many times they have occured. What I think you are saying is it is time for a service call for repairs, yes? Or are there components I can buy and replace for this problem?
  • Kenneth Boutin Jul 20, 2007
    Update to the blinking red power light. I saw another entry with the same symptoms (6 red blinks then a pause, no power) and decided to try replacing the thermal fuse, Sony part number 191002393 per the recommended fix. The original fuse sits directly under the bulb and ostensibly will keep the set from getting too hot by blowing and cutting power to the lamp circuit. The original thermal fuse is visible when you take the bulb out and can be accessed through the front, but you will need to take the rear cover of the unit off and remove the fan so you can have access from both the front and the back. Easy fix. The new thermal fuse is much smaller and simple to install. Set works great!
  • Anonymous May 15, 2008
    Hi , i have a 32" sony bravia and it stuggles to start up , message in corner of screen says " launching " but nothing happens , finally it flashes red led 10 times , which i presume is the fault code .Tv is a virtually new Sony seconds product that worked the first day only , fitted a rear mount then it wouldnt work after that ??? , reverted back to std base and problem is still same ???
    any help greatly appreciated , thanks Pete j
  • 432 Answers
It sounds like the horizontal (H stop) and vertical (V stop) has gone bad. Check Cap 515 and 516. IC1509, Q1505 and the jungle IC, IC206. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC.
Posted on Jul 07, 2007
  • Raymond Scott
    Raymond Scott Jul 07, 2007
    If you know which components to replace, you can buy them yourself off the internet or a TV repair shop. That would save you some money. Parts really aren't that expensive for this type of TV. It's the labor charges that kill us. Most shops have a beginning rate of $100.
Sharp Aquos LC45GX6U & TU-GD10U. The unit doesn't power up, and has a red blinking light from the moment you plug it in. The unit works fine in service mode.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Sep 27, 2015 | Sharp Aquos LC-45GX6U 45 in. HD-Ready LCD...
My panasonic plasma hd tv red light flashes 10 times and will not come on
Check its fan SOS board for fault. Visit this site for more details. Pull up older posts. Blinking codes to Panasonic Plasmas are given in detail.
Mar 31, 2013 | Televison & Video
My Toshiba 50H81 screen black, no sound & power light blinking
sounds as if your power supply needs to be repaired. the capacitors over heat and crown or leak.
Jan 01, 2010 | Toshiba 50H81 50" Rear Projection...
Our 52" widescreen LCD TV just quit working.
This set uses a lamp ( not picture tubes ) The part # is TS-CL110U. Almost certainly it is bad. They are easily obtainable and you can easily change it yourself.
Apr 09, 2009 | JVC HD-52G787 52" Projection Television
Red light blinking three times in a row
Service manual says 3 flashing red leds = eeprom error (main digital / video pcb).
Suggest you start by implementation of Fujitsu Service Bulletin PDP 0068-01 Main Digital pcb see:-ttp://www.eserviceinfo.com/download.php?fileid=43450
Mar 31, 2009 | Fujitsu Plasmavision P42HHA10 42 in....
Sony KDF-46E2000 - Screen Goes Blank
The lamp can cause the picture to cycle without spitting out a lamp error. I'd replace the lamp and clean out the dust/dirt from fans, etc to hopefully resolve your issues.
Dec 06, 2008 | Televison & Video
Blinking red light
I DO HAVE THE SAME PROBLEM , ONLY THE RED LIGHT BLINKING ,NO SOUND NO PICTURE '
PLEASE I DO NEED HELP TO FIX IT .THNKS
Nov 15, 2008 | Akai LCT2715 27 in. LCD Television
Tv wont turn on
TV STARTS UP AND GOES BLANK SOUND NO PICTURE
May 16, 2008 | Philips 32PF5321 32 in. HD-Ready LCD...
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Screen went black
I am working on one right now with a similiar problem. The power supply is bad in the one I am working on, and sadly, the part is not made anymore. I hope you have better luck than I am finding the bad component in yours. Sorry for the negitive answer.
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Televison & Video
Sony KDF-E55A20 55 in. LCD Television Logo
412 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
