Question about Canon PC-1060 Black and White Copier
Copies have several dirty streaks across the pages
Copies have horizontal dirty streaks, more dense in the middle than at the edges. Also, there is a thin vertical stripe down the middle of the page.
I assume this might be a problem with the toner cartridge (which I assume includes the drum), but I don't want to spend $160 on a new cartridge and discover that was not the problem! I have run the drum cleaning procedure. The problem is not the ADF; it occurs even when copying a plain sheet of paper on the glass.
This unit is used at home, and not all that frequently; the cartridge has been in the copier for about 3 years and is probably about halfway through its estimated 5000-copy capacity.
  • ronwm4 Jan 24, 2009
    You're right! Replacing the toner cartridge solved the problem. I've used laser copiers and printers since they were introduced, and I've only seen light streaks as indicators that toner is needed, not dark streaks. I still don't understand it, but I do appreciate your insight! Thank you.
  • Canon Master
  • 19,396 Answers
That often happpens because toner dust had spread inside the printer,
Follow suggestions below to clean the printer:
Clean your laser printer safely
Posted on Jan 23, 2009
    Sergeant:
  • 221 Answers
Yes its the toner got empty problem.just replace it or refill it.confirm will get solved.
thanks.
Posted on Jan 22, 2009
Canon NP6221 copier makes copies with black streak down middle.
I suggest You Go to Official Canon Printer Page For You Canon Problem On Below Canon Page URL:
Copy Has Vertical Black Streaks In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Canon Printer Support
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
Horizontal streaks and smears across whole page. Still does this with lightest setting. Can't read copies at all. Model- ricoh aficio 1018
sounds like the recycling pipe is blocked or cleaning blade has worn out
You need to take the drum unit appart and vac out the recycling coil and clean the cleaning blade.
Nov 21, 2010 | Ricoh Aficio 1018D Copier
I have long yellow streaks on copies.
Hi, Sounds like the yellow PCU is faulty, pressuming the streaks are vertically down the page.
If they are horizontally across the page it is probably another issue.
Nov 02, 2010 | Ricoh Aficio SP C410DN Laser Printer
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Streaky copies
It probably has several issues - optics dirty, and drum, and blade failing. I would also imagine that even the Solid "blacks" aren't as black as they could be, and that would be the developer. This machine is in the 17 year old range, and I wouldn't spend dime on it
Mar 29, 2009 | Ricoh Office Equipment & Supplies
2 streaks down middle of page
Do the black lines go from the lead edge to the trail edge? Also, were the lines there before you replaced the drum? If so the problem lies in the fixing unit.... You most likely need a upper fixing roller.
Mar 19, 2009 | Ricoh Office Equipment & Supplies
Aficio 1035 Drum problems
if you clean the drum unit, but the copy is dark push the drum unir forward because the luck is not locked
Feb 07, 2009 | Ricoh Aficio 1035 Copier
Dirty Copies and Black Line in Middle
the electrostatic drum probubly whent out if it was a cheap copier get a new one if it was expensive have it serviced or replace the drum yourself
Jan 22, 2009 | Canon PC-940 Black and White Copier
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Horizontal streaks on pages
Streaks at 2.82 inch intervals: Horizontal marks at this interval are the result of a mark on the fusing roller of the printer. In some cases, these marks can be cleared up by running a cleaning page through the unit. Laser Printer Cleaning sheets can be purchased at your local printer/office supply store. If the marks persist, this can indicate a more serious problem with the fusing roller that would require service attention.
Streaks at 3.74 inch intervals: Horizontal marks at this interval are the result of a mark on the image drum of the printer. There is no way to repair a damaged photosensitive image drum, so in the case that it is scratched or otherwise damaged, the entire CRU (toner/drum cartridge) would require replacement to clear up these marks.
Dec 03, 2007 | GCC Technologies Elite 12/1200N Laser...
Canon PC-1060 Black and White Copier Logo
134 people viewed this question
old marine
old marine
