Question about RCA HD52W58 52" TV
All the sudden pitcher is bowed and colors are sepertated
Tv was fine when we went to bed turned on this morning and the pitcher looks like a fun mirror at the fair has a big bow in it and the colors are all mest up can u help me
  • Anonymous Feb 12, 2009
    same problem, happened a couple times, but always went back to normal operation. Now its not going back. And yes, colors seperated. But no answer as well.
  • pepita4 Feb 15, 2009
    same here. think a new picture bulb. is the way to go?
    Genius:
  • 1,030 Answers
This is convergence. First read FL231 fuse problem in tips and trick section to see if this may be the problem
Posted on Feb 18, 2009
II turned my tv off to go to bed but when I went to turn it on this morning it would not come on.
going to have to look inside the set, follow the power cord to the main ac fuse and see if bad or good.
Dec 22, 2012 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
Are there special toddler beds just for boys? I'm moving my son out of his crib soon and wanted to make it fun for him.
You can get some really fun beds for boys that are themed or just in boy-friendly colors. Take a look at this link to the toys'r'us site: http://www.toysrus.com/family/index.jsp?categoryId=2256286
If you don't find a bed that you want, you could always buy some very fun linen.
Aug 14, 2012 | Baby Gear
I have a JVC model HD-52G886 tv. that loses sound.
Replace or have replaced the Audio board in the set----a lot of them fail.
Mar 12, 2012 | JVC HD-52G786 52" Rear Projection HDTV
Looks 3d,bows in the middle
You must replace conversion IC's (2)
Part number: STK 392-xxx
Also check resitors in circuit for>>open
easy repair!
May 19, 2010 | Sony KP-43HT20 43" Rear Projection...
I have a blue wave on my screen
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix on the Hitachi sets.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Jan 28, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Old toshiba proj. t.v. red color bowed and not aligned
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Jan 04, 2009 | Toshiba TP50H50 50" Rear Projection...
TV will not come on.
check to see if the power cord is pluged in firmly
Dec 17, 2008 | Sylvania 6427GFG 27" TV
TV Turning on and off, left side of picture is not lining up, bowed in center
Most likely you had a power surge issue that caused the tubes in your crt projection to malfunction. I would recommend having a service call done to find out the issue
Apr 22, 2008 | RCA P61960 61" Rear Projection Television
RCA HD52W58 52" TV Logo
71 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
