Question about Vintage Air 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980 Chevy/ GMC Pickup Truck with Factory AC Complete Gen IV SureFit System Kit 944175"
1978 chevy truck wiper diagram - Vintage Air 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980 Chevy/ GMC Pickup Truck with Factory AC Complete Gen IV SureFit System Kit 944175"
Do you have a diagram for the belts on a 1978 1 ton Chevy van?
Every 1978 Chevy van was shipped with a sticker affixed to the engine shroud, showing a diagram of the belt threading. If this sticker is lost, you're a little lost as well, since the belt threading varies with engine and optional equipment (such as air conditioning, California emissions, power steering, etc.).
Your best bet if you can't find the sticker is to do an Internet search for "1978 Chevy belt routing) and see which engine configuration most closely matches what you have... and install the belts THAT way. Sorry I couldn't provide a definitive answer!
May 21, 2015 | Chevrolet Cars & Trucks
Need wiring diagram for wiper motor on 1978 VW super beatle
I am sorry we do not have any wiring diagrams.
Apr 04, 2012 | Cars & Trucks
1978 Pontiac Transam, wiper motor, wiper switch and transmission all work fine.. can not get the wipers to work, Where are we going wrong. There is power to all 3 sources all wires are working.
Interesting problem! Since you have power to all three, it isn't the fuse. I can't download the diagrams right now, but I think there is a wiper pulse module in the 1978 Pontiac Transam. While it mainly controls the intermitant or delay wiper mode, if it shorted out it could cause nothing to work right. You need to verify that you do have that module first.
Jun 01, 2011 | 1979 Pontiac Firebird
I would like to have a schematic for a 1978 Ford LTD Wiper motor and switch diagram. Can you help? Thanks, Gene
If you have intermittent, it's on the right. Regular is on the left. Both use the 2 fuses.
Oct 26, 2010 | Ford LTD Cars & Trucks
Vacuum diagram for 78 chevy c10 pu 250 inline 6
1978 Chevrolet Truck C10 1/2 ton P/U 2WD 4.1L 1BL 6cyl
Fig. 14: Vacuum hose schematic - 1978 250 engine, light duty emissions (except California)
Fig. 15: Vacuum hose schematic - 1978 250 engine, light duty emissions (California)
Hope helps (remember to rate this answer).
Oct 08, 2010 | Chevrolet 1500 Cars & Trucks
I need the vacuum hose diagram for a 1978 chevy. el camino 350 eng. 4-barrel crb.
This one is not for California. If you have california car, please let me know
Sep 17, 2010 | Chevrolet El Camino Cars & Trucks
What is the 94 Chevy Caprice Classic wiper arm
heres a wiper linkage asm diagram, the wiper washers are on the hood or on the cover to deck,then the hose runs through the wiper arm to a nozzle, if you remove the arms you can lift cover enough to look at the hose to washer connection,also check hose to arm they often break there good luck.2d8c418.gif
Mar 30, 2010 | 1994 Chevrolet Caprice Classic
I have a 1998 chevy z-28. need to know how the
The wiper motor has a place for a plug in and the wires should be in a plug that fits it, if you just have loose wires, then someone has cut the plug off and you'll need to replace it.
Mar 17, 2010 | 1983 Chevrolet Camaro
Vintage Air 1973, 1974, 1975, 1976, 1977, 1978, 1979, 1980 Chevy/ GMC Pickup Truck with Factory AC Complete Gen IV SureFit System Kit 944175" Logo
Top Vintage Air Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Vintage Air Heating and Cooling Expert? Answer questions, earn points and help others
