Question about Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Kenmore oven with an error code F3
I have a kenmore oven, built in, that on occasion flashes an F3 error message. Then it shuts off. Any ideas?
  • Anonymous Apr 17, 2009
    i go to put in food bake or broil my kenmore oven n it flashes f3
  • 15,935 Answers
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 25, 2010
The oven beeped, the screen said F3, now the oven is locked. It smells like a hot wire
What does F3 mean on my Frigidaire stove when it sounds ...
www.shopyourway.com > Manage My Life > Questions
My Frigidaire range beeps and flashes F3. ... 790.92413202 and when I turn on bake or broil it just shows an F3 code on the screen what does this mean?
What does fault codes "F2" and "F3" mean on a Kenmore ...
I have a Kenmore wall oven model 911.41059591 that beeps and flashes F2 or F3 and shuts off. ... The "F2" and "F3" fault codes is most likely indicating an open oven ... Next, the control panel will need to be taken off in order to measure the ...
Oven error code "F2" and how to fix it ' AskGene.com
www.askgene.com/.../oven.../what-means-the-error-code-"f2"-on-your-o...
Mar 26, 2007 - The error code "F2" will be displayed along with a beeping sound if the
Jan 27, 2016 | Kitchen Ranges
Why does my kenmore range beep and show an error code every time I open the oven door?
See if this helps...
http://link.brightcove.com/services/player/bcpid1910171499001?bckey=AQ~~,AAABAWGODxk~,hLHEX2tm6AFlgSDzRIBPGX7yjI__nHLT&bctid=1974107068001
Also
Sometimes shutting off the circuit breaker that the range or oven is connected to for 30 seconds will clear the fault, error or function code.
Also
F3 or F30 means that there may be a problem with the oven sensor.
Your oven sensor may need to be replaced.
Jul 08, 2014 | Kenmore Kitchen Ranges
Oven will say F3 and shut down what does F3 mean no book?
Kenmore' F2 or F3 usually points to an open oven temperature sensor. If that is the problem, it's not an expensive repair.
Mar 02, 2014 | Kenmore Ovens
91136669891 HAS ERROR CODE F2 F3
Are you sure about this error? The 91136669891 was made by Whirlpool for the Kenmore line. The 4 character codes for these ranges are F# E# (not two Fs).
Depending on which error you are actually have see below.
If the code includes F3 then you have a problem with the oven temperature sensor (F3 E2 would be temperature too high). You need to replace the sensor. Sears Parts Direct has the sensor for $74.12: http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Range-Parts/WB21X5301/0022/364/Model-91136669891/0582/0124250?keySuffixId=NA&pathTaken=partSearch&pathRender=modelComponent&documentCompId=P9040087&diagramPageId=00005&productTypeId=x&searchModelNumber=91136669891&subCompDesc=Body&brandDesc=KENMORE&modelDesc=30 . The complete diagram of the oven parts is available here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00005?blt=06&prst=&shdMod= . The sensor is part 253.
If the code includes F2, then double check the second code. Whirlpool has no F2 E3 error that I know of. However, F2 errors tend to be a problem with the keypad. Check the wiring connection between the keypad and the control. This should be firm. Then press Cancel. If the error persists, you need to replace the keypad. See http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Range-Parts/Model-91136669891/0582/0124250/P9040087/00001?blt=06&prst=&shdMod= for the parts diagram and prices.
I hope this helps.
Nov 23, 2011 | Kenmore Kitchen Ranges
Kenmore built-in oven model 911.30168792 displays F3 code and shuts down... what part might need replacement... or is it more economical to just plain get a new oven?
The F3 error code means that the oven tempature sensor has shorted out,its fairly easy to replace the sensor and it cost around $80 or so. It is located in the oven chamber typically on the upper left side.
If you want to replace it the part number is WB21X5301 it could be purchased at your local appliance parts store or online at;
apdepot.com
partselect.com
apwanger.com
repairclinic.com
here is what the sensor looks like
Aug 29, 2011 | Kenmore 91112 / 91114 / 91117 Electric...
1996 kenmore oven error code F3 ?
An F-3 error message usually indicates a problem in the oven temperature sensor or its wiring circuit.
Replace it and that will solve your problem; can purchase at www3.sears.com
Hope helps.
May 04, 2011 | Kenmore 49022 Electric Single Oven
I have a Kenmore Super Capacity with UltraBake System. Model number 92004102. I keep getting error message E2 F3 and my oven door locks and my oven turns off. What does this earor message mean?
We have parts for your Kenmore range. You have a series of 3 numbers before the model number that's on your range. Those numbers tell us who manufacured your oven. Once we have this information, we call tell you which part you need to stop the E2 F3 error codes.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST Monday through Saturday and we can get you cooking again!
We look forward to working with you and getting you up and running again soon.
Thanks, Ella
Dec 11, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Kenmore double oven flashing "door locked"
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Jul 16, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
What does F3 mean from my Kenmore Oven??
f3 is a bad sensor part number WP8053344 this reads the temp. in the oven just like on older ovens had a thermostat.if you look into the oven you'll see it go here and look at picture
https://www.repairclinic.com/PartDetail/Temperature-Sensor/WP8053344/722235
go here to see error codes
http://www.appliancepartspros.com/repair-help/whirlpool-fault-codes.html
Nov 13, 2017 | Kenmore Ovens
Shuts off when preheating with F3 or F6 error
The F3 error on this model is an open thermostat circuit. The F6 is a control or loss of power. Make sure the unit is plugged into a good 120 Volt outlet. Test this outlet with a power drill or lamp, wiggle cord in receptacle, if no other test experience or equipment is avaliable. Check the thermostate in the oven for physical damage. There may be a loose connection in the oven. This would require a good technican to find.
InMrFixIt
Feb 20, 2009 | Kenmore 33169 Gas Single Oven
Kenmore 47153 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
308 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
