Question about Frigidaire Freezers
My upright frigidaire commercial freezer has no power. Is there a reset button? I have tried different outlets. I kept having to reset my outdoor outlet as the freezer is in the garage. Now I have pow
8 years old. upright.
    Sergeant:
    Champion:
  • 249 Answers
What is your model number is then we can get started the
Posted on Jan 18, 2013
watugot
  • 290 Answers
SOURCE: Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Posted on Sep 26, 2007
fridgetech
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
jaylex
  • 417 Answers
SOURCE: Proline FS 707 Upright freezer -problem
Check that the air vent is free from anything blocking it at it maybe over heating.
Thanks J
Posted on Feb 16, 2008
22yooper
  • 828 Answers
SOURCE: Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Posted on Jun 10, 2008
  • 311 Answers
SOURCE: Freezer not Freezing
If unit is running then it is not worth fixing. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
Upright frigidaire freezer light flashing 6 degrees pressed super freeze will it reset??? How do I know if super freeze button working??
Check along the back and sides of the freezer for any vent-like openings that are covered or blocked by packages. There may be a sensor that's not getting air flow as it should. Although most upright freezers are now frost free, there still can be ice buildup in critical areas such as the thermal sensor or the fan. Can you tell if the fan is running?
Even if the compressor has failed, your frozen items will keep the temp down for several days. I suggest you move the frozen goods to a neighbor immediately. Meat or fish in particular quickly becomes unsafe to eat without at least refrigeration.
Sep 03, 2016 | Frigidaire Freezers
The light bulb in my My Frigidaire fkfh21f7hwa upright freezer started blinking and the fan would stop running whenever I open the door. The control panel would also beep and flash between 0 and 1. I
Hello Ricco, thanks for your post!
Based off the information you have provided it sounds like a possible issue with your control panel or power cord within your Frigidaire freezer. I would recommend performing a reset on your freezer and you can do that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue with the freezer I would recommend consulting with a professional technician for a proper diagnosis to be completed. Best of luck! -Matt
Jan 10, 2015 | Frigidaire Freezers
My upright Frigidaire freezer stopped running. I have checked the outlet and it functions just fine. The light doesn't come on, no controls work makes no noises. Acts like there is no power to...
Hello Ed Greene, thank you for your inquiry!
I see that your Frigidaire freezer is not operating. You explained that the outlet is working and the lights or controls are non-operational. It sounds like a potential issue with the power cord or control panel within your freezer. It would be best to have a technician come out to the home to review the freezer to diagnosis the correct problem and replace parts as necessary. This will help avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Dec 12, 2014 | Frigidaire Freezers
Frigidaire commercial upright freezer
Try replacing the relay/overload on the compressor, if that doesn't fix the problem then you have a bad compressor
Dec 10, 2013 | Freezers
Upright frigidaire commercial freezer has no power, we had a flood in the basement. I unplugged it now the the water is gone, it will not power back on. Is there a reset button or did the moror fry from...
Water damage is hard to remove because it could have goten to the electrical parts: motor, compressor, timer, etc.. while it was still running. you need a volt meter to test these parts out no reset sorry
if it was running with water then toss it out...
sorry
call a service guy and he will tell you the same for $80!!! save your money
you can try to raise your freezwer off the ground when you get your new one...
hope this was helpful
Mar 28, 2010 | Freezers
Frigidaire MOdel LFFU1765DW9 This is a commercial self defrosting model freezer, upright, and water leaks out of the bottom right side every so often. Why and what should I look for to fix it.
I have a frifigidaire freezer LFFU1765DW9 . it is not cold at all the light in side is on the power is on but the fan no run and the compressor is not run.
Help please
Jun 21, 2009 | Frigidaire Freezer Refrigeration White...
Freezers Logo
333 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
