Question about Garden
Parking brake linkage lx176
When i engaged parking brake something broke and tractor will not start
  • 376 Answers
SOURCE: Tractor Will Not Move And Dies When Brake Is Released
I would check the wires and clean the connectors and make sure seat switch is working. If that is not working, it's like getting off the seat without holding the brake/clutch pedal down or getting off seat with blades engaged. Both will cause engine to die.
Posted on May 26, 2009
wikkidd420
  • 96 Answers
SOURCE: Craftsman Lawn Tractor dies when cluch/blades are engaged and ...
The way you describe your problem, all of it could be caused just by the seat cushion pressure switch. It is possible to by-pass this by putting a jumper across the terminals, but it is there as a safety feature, preventing you from falling out of the seat and under the blades, or in case of a rollover, it automatically kills the engine. If you by-pass this, it is at your own risk, but i did the same thing on mine. Hope this helps :)
Posted on Jun 12, 2009
bbreton
  • 437 Answers
SOURCE: tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
Posted on Sep 28, 2009
nova2nv
  • 197 Answers
SOURCE: John Deere Lawn Tractor LX176. Battery discharge
Locate voltage regulator above battery to the left as you sit on machine,its behind frame that supports steering wheel.Once you have found it use a light to shine on harness and follow the brown wire that leads into regulator.The plastic around that wire should not be burnt or showing any other color.The LX series machines had a problem with brown wire coming loose and causing the charging light to stay on.Remove plug from reg and use small screwdriver to clean out wire and work it a little so it makes good contact.
Posted on Nov 13, 2009
SOURCE: have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Posted on Jan 08, 2010
How do I free a stuck foot brake?
First check to see if the parking brake mechanism is engaged, if it is and wont release lubricate it with penetrating oil and work it in to all moving parts, working them back and forth until they move freely, if it has been setting outside for a long time, you may just have to do this with the brake pedal and linkage also.
Oct 28, 2015 | Husqvarna Garden
Parking brake does not seem to hold on moderate incline. Footbrake will sometimes not stop the machine. Are there any known issues with braking on X320
Most all mowers and tractors have mechanical brake rid adjusters..just follow the linkage from the pedal to the brake rigging...you should find some adjusting in the linkage...good luck..
Sep 03, 2015 | Garden
SR1642 Snapper rear engine, what is the fuse for?
Most the fuse is for starting. The park brake probably has a safety switch. It needed adjusted.
Jun 24, 2014 | Snapper NXT2346 46" 23HP NXT Lawn Tractor
JD 855 the idle spring broke and th hydrostatic pedals would not return to their neturel position . before I new what had happene I pushed the reverse and the tractor lunged backward then I pushed the...
Yes there is a safety switch.And this safety switch has to be engaged.If its not engaged then the JD tractor will not start. On JD 855 the safty switch is located under the seat, There is a rod that must be depressed before engage Somehow that rod is bent or its not pressing the switch to the point that the seat would not fully engage the safty switch.In some cases the switch itself is faulty.It has to be checked . Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jul 20, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Mower wont engage
The problem is in the park brake circuit,either the wires are off,the switch is bad or the park brake is on.Also check the switch under the hood near the linkage for the pto lever.
Jun 05, 2010 | Garden
My 2008 Troy Bilt Pony lawn tractor will not engage in iether forward or reverse. No clear reason just stopped working. The transmission locks up and the tract or will not start either (probably because it...
Make sure the brake pedal is fully depressing. Check the linkages for the forward / reverse and brake pedal. Check for grass build up causing the linkages to bind.
Nov 26, 2017 | Garden
The parking brake will not release. I am depressing the parking brake.
its got to be a linkage problem get up under there and have someone try to disengage the brake and see what isnt working,sounds like a definite linkage problem
Sep 17, 2009 | John Deere Garden
My toyota t100 broke down in a parking lot while i was driving. i pushed it into a parking space and put it in park and engaged the parking brake. later on that day i attempted to move my truck but when i...
Either remove the drivers side rear wheel and disconnect linkage or cut the cable from underneath (do this as a last resort... if you want to keep your emergency brake for future use, you'll have to replace the cable.)
Jun 10, 2009 | 1993 Toyota T100
Shifter issue?
Hi their.Yes there is a place that's not to hard to adjust. Underneath the truck on drives side there is an adjustment there.Make sure nothing was broke in the slamming on the shifter..
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Mar 29, 2009 | 1996 Toyota 4Runner
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
