Question about Konus Optics
Illumination not bright - Konus Optics
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
Deh p8000r having problems with illumination won't get bright enough to see display
Hello! A resistive connection on the vehicle's illumination lead is the prime suspect...If you know the wire color for this signal, make sure it's a good solid connection to the P8000R's illumination wire...If you do not know the wire color send a comment with the year and make of your auto...
Guru........Saailer
Mar 29, 2010 | Pioneer DEH-P8000R
Just bought a civic type r on 08 plate-when i put the headlamps on the dashboard illumination isnt very bright but is bright when driving in daylight
somewhere there should be a adjuster for the brightness normally down on right hand side of dashbored will have a picture of a clock most cars have them hope this helps
Feb 02, 2010 | Honda Civic Coupe
Flip up screen won,t illuminate. dark
if the screen needs to be wired to the dash light switch it will not change unless the lights are on, if the wire is disconnected it is possible to bypass it making the screen stay bright.
although it would seem more likely that the brightness could be adjusted on the unit settings or by a button on the unit itself
Nov 10, 2009 | Pioneer AVH-P5700DVD Car DVD Player
I just installed a Clarion max385vd. When we turn the headlights on, the buttons and screen illumination on the head unit keep flashing from dim to bright. Everything else is working perfect.
illumination wire does not need to be installed on this model. depending on your car, it may use odd voltage for the dash lights. Clip and tape off the illumination wire going to the harness.
Dec 26, 2008 | Clarion MAX385VD Car DVD Player
Orange = Illumination
Some vehicles have an illumination signal that tells the stereo when your headlights are turned on so that it can dim the display (to help keep from being blinded by overly bright stereo displays at night). If you don't have that signal, don't connect the stereo wire to anything.
Mar 28, 2008 | Pioneer Premier DEH-P580MP CD Player
Brightness
since you have moved your tv to 100 have the bulb at the side replace this is the light tha illuminate the screen.good luck.
May 02, 2007 | Philips 23PF5320 23 in. HD-Ready LCD...
Optics Logo
16 people viewed this question
Top Konus Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Schmit
Mark Schmit
Are you a Konus Optic Expert? Answer questions, earn points and help others
