Question about Edirol UA-4FX External Sound System
EDIROL UA4FX, IMPOSSIBLE TO SWITCH FROM 44100 TO 48000 IN CUBASE OR AUDIO DEVICES
I've been trying to switch from cubase sx the sample rate of the project which i'm unable, since the only options i get is 44.100, also when trying to switch it from the EDIROL's device, its impossible to switch and there are no checklists, droplists, clickable options or any button to change the sample rate. PLEASE HELP!!!, i'm stuck w my band trying to finish our demo and it just turns out its messed up :(!
3 Suggested Answers
jonniewalker
  • 1029 Answers
SOURCE: Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
Posted on May 25, 2008
Dr_Joseph
  • 86 Answers
SOURCE: Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Posted on Jan 25, 2009
I have an error message that says: Error wile trying to synchronize Audio and MIDI Sample Rate 38441 reciognized. Check conflict between GarageBand and external device. Any suggestions?
what you need is a "FULL DUPLEX ASIO DRIVE",which you get with programs like cubase sx, this is like a universal driver which has always synced any audio equipment i've hooked up to my computer, internal & external.make sure it's the full duplex & not the asio4all v2.
But really you shouldn't be having much trouble if your using a USB midi interface.unless your computers sound card is ****.
try resetting the sound cards sample rate to 44100HZ which is the standard rate for most audio,or 48000HZ for digital.
May 16, 2011 | Tascam US122 Audio/MIDI Interface with...
Will this work with cubase le4?
cubase le is a learning series. you can try in cubase sx or nuendo for good result.
Apr 06, 2010 | Steinberg Cubase System 4 USB Audio...
Tascam us-144 mkII now working with cubase le4
better , you can use it by nuendo or cubase sx. over all you try it cubase device setup and click vst system or switch vst audio bay. for more help call me +8801711904316
Apr 05, 2010 | Tascam US-144 Sound Card
Can't export song as audio mixdown on Cubase SX
I had this same problem, only it was after a reinstallation. Fixed it by changing the Output in the Audio Mixdown settings box to
"BUS 1 (Stereo)".
Jun 14, 2009 | Steinberg Cubase SX3
Jan 25, 2009 | Edirol UA-25 External Sound System
Cubase REcording/Playback Problems
check first the sample rate maybe its to high like instead of 44k. its in 48 96 or something like that so the buffering isnt catching with the recoding . alogn with your lattency configuration must devices are ok in 512 latency.
and also be shure not to be recording directly to tyour external hard drive
in case of plugin overload issue it would not stop recording suddenly it would slow down first with some crackles and then stop or must shure freeze.
so impretty shure its somethin else.
hope it works
good luck
May 10, 2008 | Steinberg Cubase SX3
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Saving preset in Cubase
again i have the same problem. if anyone knows PLEASE TELL ME..
Aug 15, 2006 | Edirol HQ Orchestral (hqor)
Edirol UA-4FX External Sound System Logo
47 people viewed this question
Top Edirol Computers & Internet Experts
David
David
Ben Armstrong
Iqbal Husain
Iqbal Husain
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
