Question about Refrigerators
Kegerator is shocking me
Ive got a kegerater its a older unit. only has the 2 prung plug. (no ground) now when i plug it in i get a slight jolt when i touch the tower/metal.
however the prior owner had a ground wire attached to the side then ran it to the socket. in my upstairs my outlet is not grounded so i cant do that. what other options do i have? why is it doing this shocking?
  • tds715 Jan 22, 2009
    thank you for your reply
    so if i understand its shocking me becuase the plug is switched around?
    I am unable to add a ground to the water line because of this location.
  • 61 Answers
YOU NEED TO BUY A ADAPTER FROM 3 TO 2 AND HAVE AND BE SHUR THE WIRES ARE NOT REVERS YOU HAVE A SMALL AND A LAREGE OPENING IN THE PLUG AND THE SMALL IS THE HOT WIRE IF THE ARE REVERS IT WILL SHOCK YOU ADD A GROUN GROM THE COLD WATER LINE TO THE REF. ANY SCRUE IN THE BACK. AND BE SAVE USE GOOD NON SCHOKING BOOTS.
Posted on Jan 22, 2009
Convert 3 wire plug generator to 4 wire plug cord
First verify that the voltage is the same. It sounds like you have a single phase system which is 2 voltage circuits and 1 neutral. The 4th prong will be the ground. To do this properly you will need to get a new 4-wire chord for the generator with a cap that matches the one for your house. On the Generator side, the 4th wire will attach to ground.
Oct 04, 2017 | Dryers
Cooling issues
sounds like the thermostat. can you bypass it (ie connect the two wires together) and make it run all the time? If so, replace the thermostat
Apr 22, 2014 | Nostalgia Electrics Kegerator Beer Fridge
There is a slight shock when I touch top of the water. I am afraid to get in. What could cause a shock?
The Spa is not grounded and bonded properly....find a GOOD electrician that knows how to ground and bond your spa... he will drive ground rods specifically to just ground your unit...and hook them up so that there is no chance of stray voltage...
heatman101
Aug 23, 2010 | Hayward Comfort Zone Electric Spa Heater...
My plug is a three prung plug and the dryer is a four prung plug what colors goto what on a three prung
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 17, 2010 | Kenmore 62602 Electric Dryer
I bought a Parmak Solar Pak 6. I wanted to use it
when you touch the wire, you are probably wearing shoes, which ground you,
touching it barefoot or kneeling on bare knees should provide a bit more jolt.
take your multi-meter, shove one probe in the ground and touch the wire with the other and you should get a nice reading
May 08, 2010 | Parmak Solar Fence Charger
I have a 2hp b&s motor that isn't getting spark.I had it sitting under a tarp for a while then my g/f moved it out into the rain. its an older motor off an edger. i got a new spark plug and it didn't...
Ok, change your spark plug lead and plug.If you get a "Shock" that sorta proves that it is all OK, check, ALL wiring, ends on wires, and connections are all clean and shinny. Clean with fine emery or sandpaper, That Black, wire is probably the "Kill" switch, it shorts out the Coil, to earth, and stops the motor. make sure that it's NOT touching earth.
May 06, 2010 | Briggs & Stratton Ignition Kit 2-8 HP...
Have commercial beverage air kegerator that keeps tripping fuses when plugged in, what's wrong
There is 2 kind of compressor location on those beer coolers. I have video of both. Hope that helps.
Oct 25, 2009 | Beverage-Air Kegerator - Beer Keg Cooler...
Stop working
the 4 prong cord should be connected id follows,the white wire to the middle terminal,the red wire on right terminal,the black wire on left termanal,the green wire grounded to cabinet,let me know more,do you have a meter?mike
Apr 19, 2009 | Dryers
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
