Question about Ford Vehicle Parts & Accessories
F350 speedometer issue - Ford Vehicle Parts & Accessories
    Sergeant:
  • 303 Answers
Depending on the year the truck is and what the speedometer is doing could determine how easy or difficult it will be to fix if the speedomoter is bouncing from a low to high reading most times it's the sensor on the rear differential housing going bad also if it has stopped working is same problem the other problem could be the cable itself or the sensor ans linkage at the transmission, but is most likely the rear sensor. that is located on the top of the differential housing and is held in by one bolt and is easily removed after taking the bolt out.
Posted on Nov 05, 2015
Speedometeer
2009 piaggio fly 150, speedometer won't work move?
Mar 27, 2014 | Reliance 1997-2002 Ford F150 F250 F350...
1994 Nissan pu speedometer quit working
SPEEDOMETER TROUBLESHOOTING
Can be loose speedo wiring connectors under instrument panel or its issue with speed sensor on transmission.
I suggest you to go through help links mentioned below with appropriate solutions to confirm the problem :------
How to trouble shoot speedometer?
http://schematicsdiagram.blogspot.com/2011/06/speedometer-not-working.html
1996 fiat bravo speedometer not working?
http://technoanswers.blogspot.com/2012/01/1996-fiat-bravo-speedometer-not-working.html
Speedometer works but odometer not working?
http://technoanswers.blogspot.in/2012/01/speedometer-works-but-odometer-not.html
Speedometer runs backward?
http://technoanswers.blogspot.com/2012/01/speedometer-runs-backward.html
Warning lights on and speedometer died?
http://howtobyme.blogspot.com/2011/08/warning-lights-on-and-speedometer-died.ht
Speedometer not working on 1993 Ford F350?
http://repairhelpcenter.blogspot.in/2012/02/speedometer-not-working-on-1993-ford.html
ABS & Brake lights warning indicator steady on dash and speedometer not working for Dodge Ram?
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
Vehicles Cluster panel Not reading Miles?
http://schematicsdiagram.blogspot.com/2011/12/vehicles-cluster-panel-not-reading.html
Odometer works properly but speedometer works intermittently?
http://technoanswers.blogspot.com/2012/01/odometer-works-properly-but-speedometer.html
These will help.
Thanks.
Feb 04, 2013 | Nissan Cars & Trucks
98 jetta error code p0101
These will help.
Thanks.
Nov 27, 2012 | 2008 Volkswagen Jetta Wagon
I have a 96 ford f350 with a 7.3 diesel. The
You may have spun the speedometer cable gear off in the transmission. Try replacing the speedometer cable.
Jul 10, 2010 | 1993 Ford F350
No speedometer, overdrive flashing, will not shift to low.
sounds like the speed sensor on the back of your tranmission housing has gone out or is starting to. i would visit ur local tranny shop n have it checked out also when the overdrive light is flashing usually means there is any issue with drive n overdrive but can also be included with just the speed sensor issue
Jul 22, 2009 | 1993 Ford F350
2003 ford f350 lariat crew cab drw speedometer not working
http://arrc.epnet.com/autoapp/8687/chiltonimages/8687/86876136L.gif
Jul 09, 2009 | 2003 Ford F350 Super Duty DRW SuperCab
92 f350 speedometer quit working
there is a speed sensor in the trans it is on the left side near the shifter linkage check that first
Apr 07, 2009 | 1992 Ford F350
I have a 99 f350 powerstroke and the speedometer is staying on 40
Have your alternator checked. I had a Lincoln that had the odometer and speedometer recording at a stop. Turns out it was stray voltage from alternator traveling through my chassis.
Jan 21, 2018 | 1999 Ford F350 Regular Cab
Speedometer Needs to be reset
if you have this problem with a check engine light pull the codes to se if your speed sensor is bad and replaced, but if not try installing another alternator because they have didoes inside to convert alternate pwr to d/c power and if one diode is leaking a/c the the electronics don't know what to do.
May 22, 2008 | 2003 Ford F350 Super Duty DRW SuperCab
Vehicle Parts & Accessories Logo
60 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
