Question about Pride Jazzy 614 Hd JAZZY 614HD
Wrench light flashing - Pride Jazzy 614 Hd JAZZY 614HD
Jazzy pride select14 will only show wrench light when you turn it on all lights flash and then go off except wrench
I would start by having the battery or batteries load tested by a local auto parts store, the test is free. Give the results here.
Oct 28, 2016 | Pride Health & Beauty
Yellow wrench light ctm hs 1000
Usually a generic 'trouble' indicator. Can you read out the error codes or fault log?
Aug 20, 2014 | Health & Beauty
What does the wrench warning light on my dashboard of my 2012 nissan rogue?
its time for a service. or the mechanic who last serviced the car did not reset the service light counter
Jul 23, 2014 | 2012 Nissan Rogue S 4dr SUV 2.5L 4-cyl....
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
Wrench lite comes on and scooter will not move. I have checked the electric hook ups, all OK. I wiggled the control stick and it move for just a few feet. What could it be?
The wrench light indicates a problem count the number of flashes ie 4 flashes pause 4 flashes indicate a motor problem See my tips on flash codes. Once you get the flash code then you will have to get the chair repaired because there is no self fix for those errors Hope this helps
Jun 10, 2011 | Electric Mobility Invacare Pronto M41...
A wrench light is on the indicator and the chair will not drive. Help! Thanks, Michael
When you turn the chair on and move the jostick the wrench light will flash you need to count the number of times it flashes to determine whats wrong ie 4 flashes pause 4 flashes pause. If its 4 flashes then you have a motor problem see my tips on flash codes to determine the problem. Whatever the problem is you will have to have the chair fixed by a tech or the provider that sold you your chair Hope this helps
May 31, 2011 | Electric Mobility Invacare Pronto M41...
WRENCH LIGHT
hold down the c and 8 key this will give you a code give me the code i will tell you the fault
May 10, 2010 | Toshiba 1370 Black and White Copier
In sinkerator will only "hum" and not run to grind food
On The bottom of the unit there should be a place to put an allen wrench. Unplug unit, Insert wrench and turn the wrench back and forth this moves the blades if the blades move freely then nothing is stuck. If wrench does not move freely, with flash light inspect inside of disposal (the rubber flaps are usually removable to gain better eye site) if objects (bones, utensil, etc) are noticed remove them and try the wrench again if now freed problem solved. If wrench turned freely from the beginning and motor still hums. Replace disposal.
I hope this has answered your question, please rate how helpful the answer was. Good Luck and Have a great day.
Apr 03, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Pride Jazzy 614 Hd JAZZY 614HD Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
