Question about LG DLE2512W Electric Dryer
Normal, delicate LEDs blink; rotor starts, then stops
When I press the power bottom, the LEDs normal and delicate blink continuosly. When I press the start bottom; rotor starts, rotates a bit and stops
OK. Here is the real solution: the dry sensor itself needs to be clean. There is an excess of clothing fiber deposited over the sensor. When you use "sensor dry" the sensor is not detecting humitity flow and it "thinks" that the clothes are dry, therefore it turns the machine off after a minute of operation. The sensor is located on the right side of the plastic grill where the filter is inserted. Stick you head inside the dryer and look down towards the mounting plastic grill and you will see it. You will see 4 holes where the screws are installed to mount the grill. Remove the screws and you will release the sensor. You will see the black and white wires connecting to it when it comes loose. I don't think that it matters where each one is connected, but I did mark them in order to re-install them back to their original connectors. The sensor is made of two metal pieces that run parallel to each other. Disconnect the wires after releasing the sensor. Use a vacuum to clean it. I actually washed it to remove all fiber dust from the surface of the plates and dry it with a hair dryer. Clean it very well so you do have to do it again anytime soon. Re-install the sensor and reset the dryer. This should do the trick... Good Luck!
Posted on Jun 17, 2008
    Champion:
  • 210 Answers
The blinking lights on an LG is telling you there is a problem with the door /light switch. Check the connection and replace if necessary. This should solve the problem.
Sgt 48
Posted on Jun 07, 2008
  • 883 Answers
Try to test continuity of heating coil with an ohmmeter...power off unit before opening...should not be OPEN but should be low ohms around 2-5.
Posted on Jul 07, 2007
SOURCE:
Dishwasher stops when starting to fill
Your dishwasher is equipped with a leakage sensor located at the bottom center of the unit underneath. If any water is detected, the sensor shuts down power until the problem is corrected. Check underneath FIRST to make SURE there is no water dribbling from a small leak. Look for telltale residue trails left from evaporated water on the hoses, lines, motors, etc.
You can enter diagnostic mode by pressing and holding for 2 seconds the POWER, HEAVY, AND DELICATE BUTTONS. All the l.e.d. s will be lit for 2 seconds, then the software version will be displayed in binary code by the blinking of the WASH, DRY, CLEAN, AND CHILD LOCK l.e.d. s. Next, and this will take some practice, if there are error codes present(sets of blinking lights) you will have to read them to be able to find out where the problem(s) is.
•Press the Heavy + Delicate + Power buttons at the same time for two seconds to enter Service Test Mode.
•All LEDs are displayed for the first two seconds and then Software version will be indicated in Binary Code using LEDS ....Wash / Dry / Clean/Child Lock
•Just like the DMR series you advance through the test next mode by pressing the Normal button . However each test will run by itself (see sequence chart on next page) when test has completed an led will light to indicate test is done and you can then advance to the next test .
•Code list and descriptions located on pp#3. Note: Like the DMR series the codes are displayed during operation or test modes and are not stored in memory.
Service Test Modes & Codes
I hope the following pix are clear enough for you to read, if not I will re-send them! I hope this helps you!
Jul 16, 2015 | Samsung DMT300RFS Builtin Dishwasher
Samsun dishwasher blinking ligths auto normal and delicate
sounds like it wants you to tell it which cycle you want to use .try pressing just one LIKE normal
Apr 12, 2015 | Dishwashers
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Jan 27, 2012 | Samsung DMT300RFW Builtin Dishwasher
My laptop screen is black and caps lock and scroll key are flashing
That is a security configuration on HP Laptops, depending on the way they blink is the problem your machine has.
Here is the web page where this info is posted, in case you need more info, hope this helps you to determain.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01443366&lc=en&dlc=en&cc=uk&lang=en&rule=26781&product=3816592
This document pertains to HP Notebook PCs with the HP Unified Extensible Firmware Interface (UEFI) beginning in late-2008. On startup, you may see a blank screen. If the diagnostic utilities detect a specific problem with hardware components, the fan turns on, but the screen remains blank. To help identify the cause of the problem, various LED lights on the keyboard blink a series of codes. The diagnostic utilities use the LEDs near the Num Lock or Caps Lock keys to blink a series of error codes. At the end of the series the blinking stops. The pattern of blinks will occur any time you attempt to start the computer until the error is resolved. Battery power LED blinks The Battery power LED indicates the condition of the power supply. When starting the computer, or when the computer is in operation, use the chart to identify the power condition. Battery Power LED Component Tested Error Condition Battery power LED off, and Caps Lock/Num Lock off Battery or AC Adapter AC adapter not connected or failure
Battery low charge or failure Battery power LED blinking Battery Insufficient charge on the battery When new computer is used for first time, the white LED light for the AC power connector blinks. Battery is still in "Shipping Mode", the light continues to blink even when AC power is connected.
To resolve, turn off notebook, connect AC power and allow battery to charge for at least 30 minutes, then start computer. LEDs near Caps Lock and Number Lock keys blink when starting notebook The LED lights near the Caps Lock and Num Lock keys will blink if an error is detected during the start up process. The LEDs will blink a number of times in a sequence and then stop. The number of blinks in the sequence indicates what component caused an error when it was being tested during start up. If the LEDs stop blinking and the computer does not start, you can press the power button again to repeat the tests. Count the number of blinks, and use the chart to identify the error condition. Knowing the number of blinks is helpful when you contact an HP support agent for technical help. Caps Lock/Num Lock LED Component Tested Error Condition LEDs blink 1 time CPU CPU not functional LEDs blink 2 times BIOS BIOS corruption failure LEDs blink 3 times Memory Module error not functional LEDs blink 4 times Graphics Graphics controller not functional LEDs blink 5 times System board General system board failure LEDs blink 6 times BIOS BIOS authentication failure
Dec 01, 2011 | HP Computers & Internet
On My Dv5-1125nr both the caps lock and num lock keeps blinking when i turn it on. It's wont boot at all. What kind of hardware problem is this?
First remove the battery and power cord for about a minute. Then plug back in and see if that helps. Otherwise please read the following:
Aug 03, 2011 | HP Pavilion dv5-1125nr Notebook
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Mar 17, 2011 | Computers & Internet
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
LG DLE2512W Electric Dryer Logo
336 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
