Question about Refrigerators
My ice maker is not working in my side-by side
The red light is blinking - and ice not being made. Is it that the filter needs to be replaced?
  • 61 Answers
THE BLICK IS A CODE IF IT BLICK 2 AND PAUSE MEED NO WARER OR THE ICE MACKE MODLE IS AD IF IT BLICKS 3 PAUSE THE TRANMITER IS BAD.
Posted on Jan 22, 2009
How do you flush water thru the water filter of my refrigerator
ice maker does not come out water to water hose and ice maker on/off switch red light two times blinking how can i repair to ice maker?
Jan 21, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
57029 Side by Side Refrigerator: ice maker not making ice and red light inside the ...
Your ice maker may be turned off. The blinking light is the sensor. The switch is right beside it. Is it in the on position?
May 16, 2010 | Kenmore 57029 Side by Side Refrigerator
The ice maker is not working and red blinks on the
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Apr 01, 2010 | KitchenAid KSCS25FKSS Side by Side...
Ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
Mar 24, 2010 | KitchenAid Superba Architect KSCS25INSS...
Have kitchen aide fridge ice maker stoped working, replaced ice maker still not working, red light blinks twice? Help
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hkhjkd
Jan 06, 2010 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped working w/red light blinking
The blinking light is an indication that your built in water filter needs to be replaced, it's in the refer. side, middle top or rear of refer.
May 25, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Seee note on ice maker stopped working, blinking red light
heatman101
rtwywy
Ice maker not working, light blinking
I contacted Sears repair service and had the Ice maker and control panel replaced.
Jan 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Refrigerators Logo
104 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
