Question about Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer
I cannot fax from the HP Solution center in my new HP Officejet. I can fax from the OfficeJet Fax Machine however. When I open the HP Solution center the HP Officejet 6480 series fax does not appear. I have tried repeatedly with HP support to fix it, but it doesn't work. What might be wrong. Thank you for the help. Sincerely, Skipi Smoot
    Genius:
  • 2,120 Answers
Try going to www.hp.com and let the website auto-detect your printer and download the drivers automatically.
Posted on Jan 23, 2009
I want to know how i can use my copy machine to a fax so i can use it for incoming or outgoing?
Install software
Make sure all cables plugged: phone cable, USB cable to computer
Send fax from computer:
- print your document to printer HP .... FAX
Send "traditional" fax:
- put your document into scanner input
- type phone number on HP Officejet keyboard
- push button "Send"
If your HP Officejet if connected to phone line, it reseiving faxes automatically.
Hope this helps
Nov 12, 2010 | HP Officejet 4215v All-in-One Printer
Our HP Officejet 4355 all-in-one fax machine cannot receive fax.
Your Machine Seems to be in "Telephone" Mode, which do not automatically recieve faxes. Please refer your manual and switch it to "Fax" or "FaxTel" mode. It will recieve faxes automatically then.
Aug 29, 2010 | HP Officejet 4355 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP Officejet 5780 connected but not connected
HI,
Please click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet J5780 All-In-One InkJet...
Slow down officejet v40 fax transmittion
Magic jack is lying to you. It is a DIGITAL phone service, fax machines are ANALOG
Feb 19, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
My new 6310 HP won't receive faxes.
Hi
when you installed did you get the fax setup wizard during the installation. If not, you can get it by opening hp solution center-> settings-> fax settings-> fax setup wizard.
You can have the HP solution center icon in the desktop or try with hp Director.
if not you can look at the
hard-copy user guide walks you through all the setup variations, depending on what type of line you have, what components (answering machine, for example), and how you want to handle incoming calls and faxes.
Good Luck
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
HP officejet 6310 cannot fax
did you have fax service on the line?
Jan 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
HP officejet 7210 fax error
HP Officejet 7210 All-In-One InkJet Printer
Error code: 405
When I send a fax I have a dial tone and the fax feeds through, I hear the other end answer it says it is sending and then I get the printed page that says: "A communication error occurred during the fax transmission."
Oct 29, 2007 | HP Officejet 7210 All-In-One InkJet...
Digital Products Hewlett Packard OfficeJet J6480 InkJet Printer Logo
280 people viewed this question
Top Digital Products Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alan Rothery
Alun Cox
Are you a Digital Products Office Equipment and Supply Expert? Answer questions, earn points and help others
