Question about JVC Rx206 Fm/am Digital Synthesizer Stereo Receiver Rx-206 Rx-206bk
JVC Rx206 Fm/Am Digital Synthesizer Stereo Receiver Rx-206 Rx-206bk does not respond when button is pushed
The unit has power and will power other components, I can tune the radio but when radio is on no sound out of the speakers.
SOURCE: JVC RX-884VBK RECEIVER
The JVC RX-884VBK is a great machine, I had it for over 5 years and had no problem at all. I came across the (NO SOUND at all) and I believe it is an easy fix. Check the Front left, there are 2 keys marked 1 and 2 for SPEAKERS output, sometimes you don't notice that you connected the speakers to 1 and the 2 key is pressed. You could have both keys pressed and you will get the sound. I hope that helps.
Posted on Jan 14, 2008
SOURCE: jvc rx-5032v audio/vido control receiver
HI MATE YOU NEED THE REMOTE
Posted on Aug 19, 2008
SOURCE: JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Posted on Mar 26, 2009
  • 667 Answers
SOURCE: I have virtually no FM receiption with my JVC RX 6000V Receiver
If you want to buy the antenna wire you could get one at radio shack that will plug into the spot you are talking about or as I used to do is put a small nail into the middle of the hole and wrap a wire, wire is 3 foot long longer the better, that is stripped around the nail, the wire only has to be stripped where it touches the nail, this is not the professional way to do this but it works the same, make sure not to push the small nail in to farand the nail fits the hole snug, Would recommend getting the one from radio shack but I have done it the way I said for ever and works fine. And you will have fm reception
Posted on Feb 18, 2010
Hitachi-mex
  • 26 Answers
SOURCE: My JVC RX-9010 receiver powers up & after a
You ned change a couple of resistors of 10 ohms at 5 watts near the digital board (Optical inputs)
Posted on Aug 22, 2010
Why no coaxial fm connector on rx-884-v?
It's only no connector,like TV antenna socket. For coaxial antena cable, just plug it to 75 ohm and ground socket. No need jack/connector.
Aug 25, 2015 | JVC Rx-884v Theater Dolby Digital...
My panasonic dvd stereo system sa-pm91d when the volume is turned above 25, it plays distorted sound, it sounds like I have incorrectly tuned a radio channel even when using the auxiliary input
Hi Gusma,
If you have Distorted sound.
    These may be the causes of the problem:
  • Make sure the speakers wires are properly connected.Check the color codes, be sure they are rightfully followed.
  • - Shorting (bare wires touching) of positive and negative speaker wires.
  • - Using speakers with an impedance lower than that rated for this unit.
  • - Straining of the speakers through excessive volume or power.
  • - Using the unit in a hot environment without proper ventilation.
I am also including a link to the User Manual. Read it thoroughly.
Best of Luck,
JP
Panasonic SC PM91D Operating Instructions Manual
Jun 26, 2015 | Panasonic Audio Players & Recorders
What Years was the JVC Rx-208bk Made?
This link suggests year 2000 (twice):
RC: JVC RX-208BK Receiver (RTI Family)
http://files.remotecentral.com/view/6345-16801-1/jvc_rx-208bk_receiver.html
Jul 16, 2014 | JVC Rx-208 Rx-208bk Am/fm Digital...
Raido i have power, just no sound coming from speakers
all cars now have radio codes.
when lost some go dead, 100% others tune ok but sound is cut only.
in your case. check fuse first
some cars have seperate amp. and its own fuse.
this is all covered in the FSM and at alldata.com. USA>
so the radio dont tune, most you can see it tune with the seek button
see it scan and stop at station, this shows you it has power.
Feb 16, 2014 | 2003 Suzuki Grand Vitara
Radio appears not to work at all. No sound.
check to see if you have 12 volts at the memory (yellow in most cases) wire it should be powered all the time the red wire is acc. key on
Jan 17, 2014 | Yamaha MCR-042 Micro Component System...
I just bought a used jvc rx9010. it powers up but no sound from any speaker and shows headphone all the time what should a layperson check???
No speakers are selected if just headphone is displayed. Press the speaker button just under the power button. No station is tuned when auto muting is displayed. Hook up an antenna to the receiver or use a different source like a cd player.
Apr 07, 2013 | JVC RX-9010V Receiver
My receiver in my boat does not respond to any of the modes. Even the power switch does not turn off the unit. I have to cut the power to turn off the device. Any ideas?
You are using a non marine radio unit in a marine enviroment.
I am going to go out on a limb here and say that the electronics are corroded and causing a short in the unit.
Aug 21, 2011 | JVC AM FM CD DET FACE CAR STEREO
My radio worked when I bought my truck but now it turns on but will not play any sound to the speakers
Park your truck in a silent place (best time to do at night) ask someone to get close to any speaker and in a silent place and turn on the radio. When turning on there should a slight "click" sound in the speaker. If there is a click sound then tune to other radio station and try if still no sound then there is a problem with your receiver circuit. If there was no click sound then either:
Your radio amp circuit is gone or
Wire connecting speaker are broken
You can trace the broken wire by physically checking the wire from speaker to head unit, if its fine then your radio needs repair.
Jun 09, 2011 | Pioneer Premier DEH-P410UB Car CD/ MP3...
JVC Rx206 Fm/am Digital Synthesizer Stereo Receiver Rx-206 Rx-206bk Logo
111 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
